Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Defrost timer This sounds like it might be the problem, but the mother board was reoplaced, what i read was that tjhe newer friges have mother boards, ..do they also have the defrost timer? Product below is not correct.
  • Anonymous Feb 03, 2009
    I have a GE profile side by side less then 1 yr. old. It started heating up to over 50 in Nov. They replaced the circuit board and now 2 mths. later it is doing the same thing. Heaps up to around 50 and cools back down and I loose all my food. The freezer seems to be fine.
  • tom_frazier2 Feb 04, 2009
    The control board was replaced as well as a solenoid. Any other suggestions?
    President:
  • 2,559 Answers
Can you check to see which of the following Model Numbers you have?,(All but the last one have the defrost built into the control board) PSW26PSRKS PSW26PSRS PSW26PSTS PSW26PSWASS
Posted on Feb 03, 2009
  • 2 more comments
  • Randy Hough
    Randy Hough Feb 03, 2009
    The posting said PSW26P
    They're 4 different PSW26P models.
    If yours is not one of them,Please let me know the complete make and model
    and I will reply with the appropriate info.
    1. PSW26P-SRKS
    2. PSW26P-SRS
    3. PSW26P-STS
    4. PSW26P-SWASS
  • Randy Hough
    I found the info I needed in the original post,I'll post back shortly with the correct info for you.
  • Randy Hough
    Ok,I just looked up the GSS25JFMCWW and on yours and you do have the defrost that is built into the control board(It has jumper pin setting for the defrost timer that if not set,will cause this type of malfunction to occur)
    The board may need replaced,but I would check the jumpers first.
    Sorry for the original info,I was going by the posting category.
  • Randy Hough
    Randy Hough Feb 04, 2009
    The only other part that controls the defrost is the sensor
Refrigerator side freezes and ice and water lines are frozen
the internal heater of the unit is not functioning and the defrost system allso check the mechanical timer of the defrost or if the unit does not have a mechanical timer it is build in in the PC board change hte PC board then it will go back to normal
Mar 23, 2013 | Frigidaire Refrigerators
My kenmore trio freezer is cold, but not the refidgerator is not, and there is frost and ice where the cold air blows in from the freezer.
Since Kenmore is manufactured by several different manufactures, you should find the model number off the equipment id tag and provide that so I can give you the best advice. It will probably be located beside the vegtable tray in that unit, but not always.
You have a defrost system failure. Your defrost system is made up of the defrost heater, defrost thermostat and defrost timer/control board (newer units have incoorporated the timer onto the control board). You will need an ohm meter to check the heater (if it isn't open - it is good) and the thermostat (low ohm reading normal 28-38 ohms) but the timer is a different story. So you will need to rule out the heater and thermostat before replacing the timer/control board.
Sep 30, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
GE MODEL# GSL22JFPH BS SERIAL# DH212339 side by side The refer will cool for about a week then frost builds up in the back of the freezer behind the panel, will defrost with hair dryer , will get...
the defrost timer is built into the mother board / but before replacing it / I would ck the heater's and if bad replace them there is a newer style and also replace the defrost terminator . and if you still have the problem then repl the main board .. mm
Sep 23, 2010 | Refrigerators
Frige and freezer will not get cold .would vent in freezer being block cause this
No that would just affect the fridge.
Make sure freezer fan is working. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 10, 2009 | Refrigerators
Where is the timer fridge keeps working nonestop
Most defrost timers are located inside the fresh food compartment and behind the control panel. Not knowing your Kenmore's model number really does not tell me if you have a timer or an Adaptive Defrost system or if the defrost is completely controlled by a mother control board. Sears uses a different model number system than everyone else so I would need the model number to tell you exactly what you do have.Older models do have the timers and I think they are easier to work with than the newer brands, But the newer brands save energy because of the electronics.
So explain why you think it's the timer. Are temperatures increasing inside the fresh food compartment and the freezer? Is a layer of frost building up on the rear wall or on the floor of there freezer compartment? I am going to send some photos in a few minutes and try to help you find out what's going on with your refrigerator, Sea Breeze
Sep 07, 2009 | Kenmore Refrigerators
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
My fridge is not keeping anything cool
The fridge gets its cold air from the freezer through a vent(damper)between the freezer and fridge.The fan in the freezer blows air throughit. There is a flap you adjust with thefridge temp. control. Make sure it's opening and closing when you adjust thefridge temp ..
If the evaporator coils behind the back panel of the freezerare icing up because of auto defrost failure that will stop the circulation ofcold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
How to checkeverything
Aug 30, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator cold but not cold enough. freezer
Jul 06, 2009 | Refrigerators
Frige freezing solid
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Frige is warm but freezer is fine! Kenmore Stainless 596.72913200
Hello , I can help. You can ohm the heater out to ensure its ok it should read very low res. less than 20 probably , you would be lucky to have a defrost timer in this unit most of these now have electronic defrost control boards that fail often , to find out which one you have take the control cover in the upper/fresh food settings area at top off and there should be a 3" by 4" small control board or a def. timer that's white or black with a harness connected to it that has 4 wires.
If you have a def. timer there is a dial you can turn until it clicks once and set it to defrost to test the cycle , if the defrost is working at this point this means the timer has quit and is not timing any longer you will need to replace the defrost timer.
If you have a control board this is most commonly the problem , replace the defrost board and you should be good to go. If you have any problems let me know , good luck. Phil
Dec 31, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
71 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
