Question about Verizon Communications Ethernet/Wireless-G Gateway DSL Starter Kit for
Trying to hook verizon UM150 card to verizon wireless DSL Gateway
My wife brought Home a Verizon wireless DSL gateway model GT704WG , and I am trying to hook it up to my Verizon UM150 broadband wireless card, I have no clue on where to start, does the wireless card plug into the computer or the gateway? the Instructions tell how to hook up to a DSL line and thats it. The sales person said that this will work with our wireless card. Please help. Thanks , Eric.
    Genius:
  • 1,605 Answers
The UM150 wireless card goes into the computer.
however, the DSL need to be wired to your computer for initial configuration.
if you just hook up the DSL as verizon say, then you will have a open wireless network, anybody can get access to your network.
Posted on Feb 04, 2009
Hi I want to know on how to setup the verizon Modem/Router I already have a Westell 6100G and i want to upgrade to the new one called Verizon Wireless modem/router model:GT704WG.
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported.
Aug 28, 2010 | Actiontec GT704WG Wireless Router...
I have a Verizon Wireless DSL Modem/Router GT704WG and I want to know how I configure my NAT type from strict to Open so that I can play Xbox live better with no restrictions
hi,
you can try to follow these steps,hope these works
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again.
thanks and God Bless
Jun 29, 2010 | Verizon Communications Ethernet/Wireless-G...
NO PSN with Actiontec GT704WG Verizon
If you can access the internet it is not a problem with the router. Are you able to access the PSN site but rejected when you enter your credentials?
Feb 04, 2010 | Actiontec GT704WG Wireless Router...
Can't connect work laptop to router (wireless or
Your work laptop probably has proxy settings in the browser. If yes, please remove it adn try. That should help .
Thanks
Ranjit
Jan 05, 2010 | Actiontec Electronics (GT724WGR) Retail...
Macbook and I-touch loses wireless connection with versalink dsl
It sounds like the dsl modem and the gateway should be sync'd in the following way:
1. Turn everything off and disconnect the dsl for a bit. Make sure even the wifi stuff is off.
2. Turn on your gateway and let it cyce up.
3. Plug the dsl ethernet cable into your gateway, and to your phone line, then plug in the power to the dsl.
This will cause the dsl modem to "find" the gateway IP address and connect.
4. Turn everything else back on.
This should eliminate all the drops...
Let me knowhow it goes...
K
Jun 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
Verizon Communications Ethernet/Wireless-G Gateway DSL Starter Kit for Logo
158 people viewed this question
Top Verizon Communications Computers & Internet Experts
David Payne
David Payne
Are you a Verizon Communications Computer and Internet Expert? Answer questions, earn points and help others
