Sir am holding hp pavilion dv4 series entertainment notebook pc in which i have touch screen and this touch screen is not working so please let me know how can i get it working. this touch screen is blue tooth, play, revind. forward, and volume and entertainment beside the power switch.
  • 58 Answers
Hi,there...do you still have cd drive for this touch screen monitor? why not to try to reinstall driver for touch screen..after you install the driver restart your computer...any change?..good luck
Posted on Feb 03, 2009
Pavilion DV4 screen wont turn on.(Overnight problem)
Since you have graphics on an external monitor, the problem is the Video Cable, or inside the Display Assembly.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3860431&lc=en&cc=us&dlc=en&lang=en&cc=us
This is a general example of a Video Cable, (Display Cable - HP), for an HP Pavilion DV4 series of Notebook PC,
http://www.ebay.com/itm/NEW-ORIGINAL-HP-PAVILION-DV4-LAPTOP-LCD-VIDEO-CABLE-DC02000IO00-486878-001-14-1-/281038275215?pt=US_Laptop_Screens_LCD_Panels&hash=item416f2fc28f
Mouse over to enlarge
The Video Cable connects to the motherboard in an area under the Keyboard, (About where the Fn key is), routes up along the motherboard, then routes up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter (Display Inverter -HP), and back of LCD screen.
It also connects to the LED backlight.
Either connections are loose, or the Video Cable (Display Cable) is damaged.
If the sheath of the cable shows apparent visual damage, so may be the tiny wires inside. (Stretched/Broken)
Connections CANNOT just be visually determined if they are loose.
You MUST physically check EACH connection.
Tightening connections does no good?
Perform a continuity test with a multimeter set to OHM's, on every wire in that Video Cable.
Have an assistant gently wiggle the cable in the middle, and check for an intermittent reading on the multimeter. Indicates broken wire if intermittent reading shows.
OR,
Take Video Cable to the nearest small computer store, and have the resident tech check it for continuity. Should just be a couple of bucks.
Use an ESD wrist strap, and connect it's alligator clip to a good ground source. (Electro Static Discharge)
Average cost is around $3 to $6.
Here is the download page for the free Service Manual, from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3860431&
Scroll down, click on -
HP Pavilion dv4 Entertainment PC - Maintenance and Service Guide
Page 92 (PDF page at Top) for motherboard side of Video Cable (Display Cable - HP)
Page 80 for LCD screen, and Screen Inverter (Display Inverter - HP), and LED backlight.
Page 82 has false statements.
Remove the display assembly:
1. Locate the wireless antenna cable (1), and remove from path (2)
Should be;
Locate the DISPLAY CABLE (1), and remove from path (2)
2. Disconnect the wireless antenna cable from the system board (3)
Should be;
2. Disconnect the DISPLAY CABLE from the system board (3)
Somebody was on crack that day.
The wireless antenna cable information that follows, is correct.
Video Cable (Display Cable) is on the Left side.
Wireless Antenna wires are on the Right side.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 13, 2013 | HP NB199UA Pavilion Notebook
Hp pavilion DV4 won't start up
It doesn't start at all. Can you see something on screen ? Have you tried to remove the battery and charger and press power buton for 30 seconds ? And put back the battery ? Try also to check RAM Memory
Oct 14, 2012 | HP Pavilion dv4-1280us Notebook
My pavilion dv4-2140us entertainment notebook is not loading windows, am getting black screen..please help i simply changed the boot settings t load all drives
This is a bad problem.
If you wrong changed booting, booting is impossible.
You must boot from a rescue disc, and configure after the bios.
JMG
Jul 17, 2011 | HP Pavilion dv42140us 141" Entertainment...
Instruction manuel book for the HP Pavilion dv4-2145dx AMD/ATI Entertainment Laptop And initially the switch on buton for this laptop
For HP Pavilion dv4 Entertainment PC - Maintenance and Service Guide
http://h10032.www1.hp.com/ctg/Manual/c01963667.pdf
For other manuals for HP Pavilion dv4-2145dx Entertainment Notebook PC http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=4121133&
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Tablets & eReaders
My Hp Pavilion dv4-2169nr Entertainment Notebook volume control button on the keyboard is not turning red when i select mute...it just stay white...can you help me fix that
Please refer to HPs website to re download the drivers.
Please note, if you are using Windows 7, the volume control will not work since there is not a windows 7 driver for it.
Mar 23, 2011 | HP Pavilion dv6000z Notebook
My hp pavillion dv4 sd card will not work
Hi
I think you can go to Hp website and go to support download and get the driver for it
Oct 28, 2010 | HP Pavilion dv1000 Notebook
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
HP Pavilion dv4-1151TX Entertainment Notebook PC price in india
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&dlc=es&cc=mx&product=3824509&lang=es
Please find complete details for HP Pavilion dv4-1151TX Entertainment Notebook PC in the above link.
The price for the same starts from HK$9,980
Thanks
Have a nice day.
Mar 20, 2009 | Computers & Internet
Reset the password for hp pavilion entertainment dv4
i dont know if this will work, restart and press f8, enter safemode and you will see 2user option, select which one will make u able to log in, if this successful,
1. system restore: restore your computer on the date before he reset the password
or
2. open control panel and create new account
the last option is format it and i know you don't want to do that.
Jan 28, 2009 | HP Pavilion dv4tse Entertainment Notebook...
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
