Question about Kitchen Ranges
St.croix pellet stove
My problem is that the window of our stove gets dirty, kinda sooty very soon after I clean the stove, like within one or two days, help!!!!
  • Kitchen Ranges Master
  • 2,651 Answers
Your either burnig the wrong type of fuel, or the fuel you are burning is wet, not burning hot enough resulting in cloudy door
Posted on Feb 03, 2009
The fan on my langcaster St. Croix stove i think needs oiling is it possable
no point as the oil will burn off in the first application and the fumes will spoil the food being cooked
call a technician to check the fan operation / replace the fan
Feb 13, 2017 | Cars & Trucks
My st croix Hastings pellet stove is 3 yrs old and is not blowing as much heat as it has in the past. What could be the problem?
Hi, Check to see if vents are free of debree (spider webs etc...) Clean fan if necessary. Also try a different pellet some pellets will burn hotter. Good Luck.
Feb 04, 2015 | Heating & Cooling
Which pellet stove do you have? A lot of pellet stoves have a part inside called a Draft Flow Switch the size of your palm and hook to the Draft Flow Switch is a Draft silicone hose and this will get clogged with debris you will need to look at your diagram to see if you have that on your stove. If you do you will need to "gingerly take off the hose and blow through it. and re connected to the draft flow Switch. After sometime the hoses become brittle. Another thing to look at is the exhaust at the back of the stove cleaned out and you are getting your pellet stove cleaned out by a chimney sweep.
Mar 03, 2014 | Us Stove Company Pellet Heater with...
Have a pellet stove that has been working perfect for years, then last night it shut itself off and when I opened door there was this black tar on everything inside and the windows were also black. I had...
Several of things come to mind: Have you changed the type (Brand) of pellets, recently?
Have you had your chimney (stack) cleaned in the past year? Is the fresh air intake functioning properly? Is the auger feeding to much or to little pellets?
Changing brand of pellets - Not all wood pellets are made the same. If you recently changed brands, you will need to tweak your stove to handle this new brand. This will affect how the auger feeds.
If you chimney (stack) hasn't been cleaned in the past 12 months, it may be partially clogged with creosote and not drawing properly and it is liquefying and running back down the chimney and not allowing for a clean burn. And could cause a chimney fire.
Fresh air intake: If that's not functioning properly, you're getting incomplete combustion. Which will cause the black tar looking substance you described. Couple that with changing brands of pellets and you have a problem.
The above are the first things that came to mind. I hope it steers you in the right direction to troubleshoot the problem. Please let me know.
Mar 28, 2011 | Heating & Cooling
I purchases an elcipse pellet stove in 1990. It still works perfectly. I need to replace the insulation blocks for the side walls and also need a new ash pan. Do you know where i can purchase these items.
Elcipse was manufactured by Warnock Hersey, but was sold to St Croix. So, their parts may be interchangeable with your stove. Try Pellet Stove and click on other brands for St Croix.
Feb 22, 2011 | Heating & Cooling
Plugged feeder on pellet stove
if u can get at it you can clean it, if you get at a little of it you may be able to hit it with a small brush or paper clip or finish nail or whatever while it is revolving. I spraye my old stoves auger with PB blaster then cleaned it and of course let it air out for 2 days as that is flamable. The cause is probably inferior non-hardwood pellets. Been there....and doing that .. good luck
Dec 07, 2009 | Stoves Heating & Cooling
St croix pellet stove
Had the same problem which I discovered this weekend..........
I have an eleven year old Afton Bay....the versa grate was not moving. I look into the inner workings of the stove and saw a bracket which had broken off....
The bracket was attached to the versa grate rod and made contact with the cam system in the stove...this is what moves the versa grate...........
I called my dealer, the part costs about $12.00 and looks like it can be replaced with out having a service guy come out..........
Hope this helps
Oct 21, 2008 | Kitchen Ranges
Kitchen Ranges Logo
326 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
