Question about Goodman GMS90703BXA Heater
I have a gooman furnace that will cycle 3 times, but never fire up. It is getting gas, occassionally it will fire up, but then after running for a while it will cycle 3 times again and not fire up
  • Anonymous Feb 03, 2009
    flash code one, which has a variety of possibile problems
  • Mark Egan May 11, 2010
    If this is a "newer" furnace, with a controller board, then you need to identify the blink codes of the LED on the controller board.There will be a chart on the unit somewhere that will tell you what the blink code means.
    Reply back what you find and I can give you additional information based on those findings..
    Problem Solver:
  • 8 Answers
Could be a flame sensor problem, maybe your ventor motor. what flash sequence does the led do?
Posted on Feb 03, 2009
Furnace reaches temperature set then shuts down and restarts 8 times before final shutdown.
When you say the the furnace re-starts 8 times before shut down, what is cycling 8 times? just the indoor blower or is the main burner re-firing 8 times? If it's only the fan it sounds like the fan control.
Mar 07, 2018 | Coleman Heating & Cooling
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
No heat from furnace
If this is the first time unit has been fired up, you likely have air in the lines to purge first. Also make sure the gas supply is on/open. and that if there is a fuse present on the control board (likely a 3 Amp fuse) make sure it has not blown (which can happen simply by close proximity lightning strikes.)
Letting the unit go through the ignition sequence several times will purge the line. If furnace "locks out" on third start attempt, shut it off and start cycling it again until the furnace comes on..
This assumes the installation was checked for leaks initially.
Oct 27, 2012 | Coleman 3.5 Ton 13 SEER Complete Split...
Have a Fridgidaire GR6C-080C-16 furnace that runs for a few minutes then gas supply is cut-off. Furnace will then re-start and the run through it's pre-cycle, just as if the thermostat just called for...
It sounds to me like you have problems with the gas valve as you have eliminated pretty much everything else. I would check all wiring to valve,check for any breaks on the insulation and clean all connections.
When the burner goes out is the blower still running or does it quit then the burner go off? If that is the case I would think the thermal overload on motor was tripping. It makes me more inclined to suspect the gas valve due to the lack of any diagnostic code.
One other thing I would try is to check power to gas valve when burner is firing and see what it does when it cuts out.If it maintains power when gas shuts off then I would replace gas valve. Good luck and thank you.
Feb 14, 2011 | Heating & Cooling
All burners will not light on Goodman furnace
I have had problems like this before. Most of the time it is the connection between the burners. There are small slots that the gas runs thru to lite. Clean those with a brush and then try it. Rus
Oct 04, 2009 | Goodman CLQ36AR49 Air Conditioner
Sterling garage heater wont always light.
The flame sensor is dirty - have the unit serviced. Modern furnaces require regular maintenance!
Mar 10, 2009 | Sterling RF30 Natural Gas Garage Heater
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Got an older modle gas dryer running on propane, have a full tank starts up and runs for 1 to 3 cycles than dosen't fire. Ignighter works just dosen't fire up. Shut it down and wait a few minutes and works...
Are you any issues with any other appliances? (i.e. Water heater, range, oven , furnace) If you are having issues with your regulator(on the propane tank), then other items would be affected also.
If your ignitor is trying to ignite, then you are not getting gas to the burner.
  1. Replace the thermacouple.
  2. If this does not fix the problem, then you are looking at a bad gas valve.
Please rate this solution
Aug 03, 2008 | Dryers
Goodman GMS90703BXA Heater Logo
56 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
