Question about Texas Instruments TI-83 Plus Calculator
I am trying to graph Y1=X-2
Everytime I put this into effect and press graph it err:invalid dim and tells you to quit what can I do to make it work. Thanks
  • 4 Answers
It sounds as if you have a plot on.  Go to y = and check the top of the screen.  Is one of the plots dark - if so it is on.  Move the cursor to the top of the screen and move it to the plot that is on.  Press enter and the plot will go off.  If more than one plot is on, repeat.  If your plots are not on try zoom 6.
Posted on Feb 03, 2009
When I try to graph it says-ERR:INVALID DIM 1:QUIT
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Nov 01, 2013 | Texas Instruments TI-83 Plus Calculator
Everytime i try to graph it say ERR: INVALID DIM and then below it, it say 1:Quit. i dont know how to fix this and i dont know where to enter the diminsions in. please help me! THANKS!
One of the statistical plots is still active and you must turn it OFF.
  1. Press [2nd][Y=] to open the (STAT PLOT) configuration screen.
  2. Press [4:PlotsOFF]
  3. The PlotsOff Command echoes on main calculator screen.
  4. Press [ENTER] to run command.
  5. Go back to [Y=] editor to edit the functions if necessary, then press [GRAPH].
Dec 17, 2010 | Texas Instruments TI-84 Plus Calculator
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
Everytime i try to graph something it says "err:invalid dim" and only gives the option to quit....how do i fix that?
Sep 24, 2010 | Texas Instruments TI-84 Plus Calculator
Everytime I tap upon the graph button it tells me "ERR: INVALID DIM". Help would be greatly appreciated.
Aug 17, 2010 | Texas Instruments TI-83 Plus Calculator
I am trying to enter a slope formula in the "y=" window, my lists are all cleared but everytime it goes to the graph it tells me "err invalid dim"
I d not understand what you mean by enter a slope formula, but I am going to assume you want to draw the graph of a function y= f(x) and you are having a problem.
  1. Press the STAT button and
  2. Select 4:PlotsOff
  3. Press ENTER
  4. Calculator displays DONE
  5. Now you can do your graphs.
Jan 14, 2010 | Texas Instruments TI-83 Plus Calculator
When graphing says ERR: INVALID DIM 1:Quit
You have two lists that don't agree in length.
Solution 1 (easy)
Press [y=] and look at the top line - one of your Plots is highlighted.
Move the arrow to the highlighted one, press enter to get it un-highlighted.
Solution 2 (permanent)
Press [STAT] - EDIT: [1] to edit your lists. Go to the bottom of the lists and see which one is the longest. Delete (DELETE, not clear) the "extra" entries in the longest list until all lists are the same length.
Oct 04, 2009 | Texas Instruments TI-83 Plus Calculator
ERR:INVALID DIM
Apr 20, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
81 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
