Solution #6
posted on Aug 01, 2007
lawyer - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
At 23:45 10/03/2000 , Moat wrote:
Ummm, I'll try and give it a shot :)
Depends on your budget :) What price are you willing to pay? What are your
special requirements? Do you shoot in macro mode often? Do you lie your
digicam to offer full manual control as well? Do you want to able to add
additional lenses later on? Do you want to be able to use external flash
synchronisation? What kind of zoom do you want (2x, 3x, 5x, etc)? These are
some of the questions to ponder.
And yes, are you willing to wait for the newer 3.34 MPixel digicams? The
ones you listed are 2.1 MPixel which should give you sufficiently good 8" x
11" printouts. The Oly 2500 is a 2.5 MPixel digicam IINM.
Well from the range of models that you post, you could be running into RM
3000 to RM 4000 budget in case you didn't already know :) I think the Oly
is much more expensive.
Here are some of my views on the cams you require;
Nikon CP 950
Pros
Very widely used. Considered a prosumer level camera. Lots of features.
Patented 256 Matrix Metering, Best Shot Selection (BSS), up to 2 cm focus
in macro mode etc. Uses Compact Flash cards. Basically you get quality
lenses that Nikon is known for :)
Also, the 2 split body design swivel lenses are useful in certain ways.
Either you like it or you hate it. Lots of people use it for
astrophotography where they use it in conjunction with telescopes to take
pictures of the moon etc. Using split body design makes it easier to use
the LCD screen to frame the picture.
You can use external flash with the help of a flash bracket. Also useful if
you do studio photography where you need to sync the external flash.
You could also purchase extra accessories like the wide angle, fisheye and
zoom lenses to be fitted on the treaded lenses.
Cons
Some anomalies / bugs in the earlier firmware. You can download the latest
firmware (version 1.3) and update it manually yourself.
Bad in low light conditions. No USB (only slow serial connection). To solve
the slow file transfers, usually a USB / Parallel card reader is used
(purchased separately as an accessory). Only 3x Optical zoom.
Cost
Around RM 3200++. My advice is if you don't need all the features, then get
the CP 800 model which is a much cheaper model. I got mine for around RM
2500. It's basically the same thing except that its only 2x zoom and
certain things missing. All the main features are the same. In fact some
additions in features like continuous shoot mode etc that is missing in the
CP 950. With the cost savings you get, you could get extra accessories like
more memory, another set of NiMH batteries and an external card reader.
The CP 990 is the newer 3.34 MPixel digicam. Definitely more expensive and
its only due out in April (next month). In Malaysia? Don't know. You can
ask Shriro (Nikon distributor in Malaysia). You know that anything new in
Malaysia is DAMN EXPENSIVE.
Olympus 2500L
Pro digicam. Lots of features. Can't remember them. Go to #
or # for in-depth review of those cams.
You could also try some of the links below here;
Some of the things unique that I can remember about the Oly 2500L is that
it accepts both Smartmedia and CompactFlash type of memory cards. It's a
true SLR type of digicam which you rarely come across but damn expensive.
Also, you cannot use the LCD screen to frame your subjects. You have to use
the eyepiece to do it whereas most other digicams let you do both ways
(i.e. LCD and through eyepiece). I think it has USB built in for file
transfers.
IMO, the 2500 is not in the same range as the Nikon 950/800 or the Sony.
You could take a look at the Oly 2020Z which is a 2.1 MPixel digicam. Price
and features are about the same range as the Nikon.
Sony DCS-505
If looks had it, this one wins :) Good Carl Zeis lens. Superb zoom (5x
optical). Best hybrid LCD screen. Still very good visibility in bright sun.
Most other digicams suffer from the LCD being blurred when coming into
contact with bright sun. Has built in USB for file transfers. The good
thing about USB is it is fast for file transfers but the bad part is your
digicam is stuck to the cable and you cannot use it until the file
transfers are complete.
One bad thing about the rather huge lens is when in macro mode, the flash
(when used) will cast a shadow of the edge of the lens.
Uses the propriety Memory Stick (comes max 64 MB a piece but in Malaysia,
you will only find 32 MB around) and propriety batteries.
One thing bad about propriety stuff is that if you later on change to a
different digicam, then all those extra accessories you bought for the
digicam will become useless.
Things like batteries and memory cards can still be used if you change
digicams. Normal batteries most digicams use are the NiMH type which saves
a lot of money if you use the digicam often. Buying a separate propriety
Sony LiON battery could cost you a bundle and could only be used in Sony
digicams and digital video recorders.
Also, if you shoot a lot, then extra memory comes in handy. The other types
of memory are the Smartmedia (32 MB max) or the CompactFlash type (128 MB
max for Type I and 340 MB IBM Microdrive for the Type II). Sony's Memory
Stick can only be used in the Sony DCS-505 or their DVs.
For digicams, you have to go to a camera shop :)
For starters, you could go to Sungei Wang. Lots of camera shops there that
carry various digicam models.
Do some homework (price comparisons) and bargain like hell (as usual) :)
Actually, as mentioned above, you could check out many other digicams like
the Oly 2020Z, Kodak DC 280 (which comes with a whopping standard 20 MB CF)
or the higher end DC290, the Canon S10 or the Nikon CP 800 which I have.
All are 2.1 MPixel digicams and in the same price range as the Nikon CP 950
except the Nikon 800 which is among the cheapest IINM.
I must say this that the Canon S10 has some bugs with regards to the
firmware where when using flash, the shutter is set to 1/15 of a second. So
you get blurry pics. Don't know if they already ironed that bug out.
Otherwise, it's a very compact and solidly built cam. Normal pics are
generally good.
No problem. So there you go. As brief as I could get hopefully I covered
most of it. If you have any questions, I'm glad to answer them (if I can).
I'm also a newbie :)
A place where you can learn a lot is the at #
where you can download text file to view it offline. Also a place to learn
is the forums at # where they have brand / model specific
forum discussing problems and tips.
Also there you can learn a lot of other things besides the basics like
optical vs digital zoom, compactflash vs smartmedia, NiMH batteries and etc.
...jason
To unsubscribe, send 'unsubscribe pcbase' to
Archives of this list can be found at #
