Can u help me? - Fujitsu-Siemens 900P LCD monitor burned out
Hi!
When I used the monitor, suddenly the screen bacame black and LED turned off.
I started to check, what causes the problem, than I discovered white smoke is coming from the top of monitor. I plugged out, and disassemled.
A found that tere are two same type IC in the power supply panel, and one of then is burned out.
A took some photo about it:
http://black-laser.uw.hu/monitor/1.jpg
http://black-laser.uw.hu/monitor/2.jpg
http://black-laser.uw.hu/monitor/3.jpg
http://black-laser.uw.hu/monitor/4.jpg
http://black-laser.uw.hu/monitor/5.jpg
Can u help, how can I repair it?
    Champion:
  • 293 Answers
Hi..there,
It's seems you got busted capacitors. Replaced all 5 capacitors in right handside with( 5*c8) in the 3-jpg photo power/inverter board.
Posted on Feb 03, 2009
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
The tv suddenly goes black and the power light blinks red
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 12, 2015 | LG 37-inch Led-lcd Tv - 1080p 60hz Hdtv...
I have (suddenly) a single dotted black line about a quarter wasy down my screen on laptop. Can I get rid of it?
First, you need to verify if the dot is cause by faulty graphics chip/card or LCD/LED. To do this use external monitor, if you cant see dot on your external monitor then you have faulty LCD/LED if you see dot like in your laptop the you have graphics chip/card problem.
Oct 09, 2014 | Acer Computers & Internet
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Monitor works ok then suddenly loose picture(black screen) turn monitor off then turn it back on works for approx 5 secs then goes back to black screen
there are many reason why a monitor suddenly turned off then back to work again , over use may over heat that cause the soled parts on the printed board of your CRT go loosen , try to re sold it, sometimes your PC might stop viewing so the monitor automatically shot off stby mode , loose connection due to basted parts , capacitors,power regulators,resistors , even the cables also might be.
Jul 10, 2011 | Fujitsu Siemens MCM 173V (White) 17" CRT...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor...
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Dec 11, 2010 | Fujitsu Siemens Siemens Premium Line P17-1...
Hello , everyone and experts people. I have a Fujitsu Siemens Esprimo Mobile V5535. laptop good start, green LED lights up, but i have a black screen without any background applications. I tried to pick...
Hi dejandan1
Sorry to hear you are having problems. The very fact you tried an external monitor shows you have some good IT skills. As long as you know this monitor works it is a good test. As you have no image try toggling the video output signal by using Fn (Function) and the CRD/LCD (Cathode Ray Tube/Liquid Crystal Display) keys or Alt (Alternate) and the CRD/LCD keys.
If this does not workthen it is either
1. Laptop on board graphics failure
2. Laptop LCD panel failure
3. Laptop inverter failure
4. Laptop backlight failure
Turn on your laptop and look closely at the screen, can you see what you would normally see but very very dark? If so it is the backlight. If you cannot see anything, which is likely, then it is the inverter, actual panle failure or grahipcs chips on the motherboard.
http://www.daileyint.com/hmdpc/lcd.htm
philswift.gif Above is a link and flow chart that will help you.
It is most cost effective to send or take the laptop in for repair. You can replace inverters yourself but there is guarantee it is that. If the graphics on the motherboard has failed then all you can do is have the motherboard replaced. If the laptop is slow and old it may be time to consider a new laptop. If the laptop is under warranty, goto the Fujitsu Siemens website and log a under warranty repair.
All the best, Phil
Dec 06, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor does...
Try connecting each monitor to a different desktop/laptop computer, to rule-out the possibility that the video-card on your own computer is the cause of the problem.
Sep 29, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Computers & Internet Logo
771 people viewed this question
David Payne
David Payne
