Purchased a new laptop and quick books pro 2009 and tried to restore quick books ver 6.0 in it via a flash drive it comes up that it is password protected
    Champion:
  • 237 Answers
This can indicate a damaged file. Or, on some flash drives you will recieve this message when you try to access the file directly on the drive.
One suggestion, try copying the file from the flash drive to the desktop. Then right click the file on the desktop, and on the properties, make sure it is not set to read only.
Posted on Mar 14, 2009
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
Can't write onto my card through adapter, only works through the phone. "write protected" keeps coming up. No lock on adapter.
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
>>>>DOWNLOAD FORMATTER CLICK HERE <<<<
Jul 14, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Just install new HP Officejet Pro 8500 printer I cannot print invoices in my Quick Books Pro 2009 program. Will print Purchase orders but not invoices
contact the developer or programmer of invoicing system. i believed the problem is in hard code in which your newly installed HP printer not supported with the invoicing system application.
Mar 25, 2010 | Computers & Internet
QB2005 wants flash player 7
Check this link: http://www.brothersoft.com/macromedia-flash-player-59871.html
Jun 25, 2009 | Intuit QuickBooks: Pro 2005 for PC
Error Message 10810 When I try and restore Time machine Backups, and where do I look for files for 1 Password and Address Book?
open adress book it have all your address and keychain access have all your password stored. rate it please
May 06, 2009 | Apple MacBook Mac Notebook
Changed year date, now it won't open quick books with out a pass
Have the administrator of Quickbooks log in mono-user mode and go under Edit --> Preferences --> Accounting --> Company Preferences Tab --> Change the closure date / password from there. He will be able to remove or assign a new password.
http://community.intuit.ca/discussion/index.php?s=f6801c4c7a7b1488da43ca74e71e37ff&showtopic=35881&pid=207042&st=0&#entry207042
Jan 07, 2009 | Intuit QuickBooks Pro 2008: Windows
APPLE I POD ERROR 1439
Hey check out this link it worked me.. http://inc0gnit0s.wordpress.com/2009/07/19/error-1439-while-trying-to-restore-or-sync-ipod-with-itunes/
Dec 15, 2008 | Apple iPod classic MP3 Player
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
