Question about Motorola Mobility RAZR V3
Screen is dim on the home screen
My phone was low on battery the other day and all of a sudden the screen went dim and a little shaky. i charged the phone and the screen wtill does not return to normal. this is a brand new phone!!
    Problem Solver:
  • 7 Answers
Loose flex cable,happens when phone gets dropped ,open it ,reinstall ribbon cable,turn on,check,close it back up.
Posted on Feb 04, 2009
How do i know when my alternator is going bad
If the batt light is on, the alternator is not charging the battery.
If the battery won't hold a charge, it could be failing.
If you are having a specific problem with your PT Cruiser or Mustang, let us know what it is.
Dec 18, 2012 | 1994 Ford Mustang
I can turn it on, and if i dial a numbre i can make a call, and if someone calls or texts me my phone will ring, but the screen is black, and i really need to fix it. Its started out with half of the...
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 10, 2012 | Nokia 7610 Supernova Cell Phone
Hi, i have a blackberry bold 9000, i went out of town for a day and forgot my charger at home and my phone was running low on battery, later that day it died. When i got home to charge it i would show the...
Dead battery. Try that first.
If that's not the case. the battery contact terminal might be bad. Which is common.
Chances are, it's just a fried battery that needs to be replaced
Sep 10, 2011 | RIM BlackBerry Bold 9000 Smartphone
My Motorola Defy will not hold a charge. Had full charge at 8:00 Am and by 2:00 PM battery was dead. No apps running or Wi-FI on. Second day in row this has happened
The DEFY is feature-rich and can run a virtually limitless number of applications, making it useful for many tasks. Your particular usage will affect how long you can go before recharging your battery. Playing games, running applications, and surfing the Web increase the power use of the computer-like functions of the DEFY Calling and texting utilize its phone functions. Depending on your use mix, time between charges will vary. We know you want to use the device to its fullest and offer you these tips to help you get the most from your phone while going as long as possible between charges.
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tip: It may take several charging cycles for your battery to reach optimum performance.
The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
Tips to extend battery life:
  • During initial set up of your MOTOBLUR account, your phone's battery may drain faster than usual due to the amount of data transferred. After the initial sync, and a few charging cycles, your battery will reach its maximum capacity.
  • We strongly recommend to keep the phone attached to the charger during the MOTOBLUR initial sync.
  • When not transmitting a lot of data or surfing the Web, set your device to connect to 2G network.
  • When setting the phone down after use, quickly press the power key to invoke a blank screen. Selecting a shorter back light duration will also help conserve power by blanking the screen when not in use.
  • Lower the display brightness.
  • Use the AC adapter to charge your phone whenever possible.
  • Toggle Bluetooth, Wi-Fi, and GPS on or off as needed. There are some apps that can help do this easily. While we do not endorse or guarantee these solutions, or provide support for them, some owners have reported success using an application called "Battery Widget " which can be downloaded from Android market.
  • Ensure applications are closed when not in use.
  • Clear all notifications from the notification bar as much as possible. Click Here to learn more about notifications.
  • We suggest charging each night so you start the day fully charged and ready to go!
Motorola DEFY Battery Manager - Benefits
A feature called Battery Manager is now part of the DEFY software
  • It provides options for significant battery savings by reducing data traffic when not needed, and by dimming screen when battery is low.
  • Two optional settings:
Data Timeout
· With this feature: After a period of inactivity, background data updates stop until the user starts using the device again.
· Without this feature: background data is constantly updated (Email, Social Networking, News Feeds, etc.), even overnight.
Auto Brightness
· When Battery Level gets low, screen automatically dims.
Battery Manager: How To Use It
To access battery manager
  1. From the home screen press the menu key
  2. Tap settings
  3. Tap battery manager
Three Modes are available:
  1. Performance Mode (default) - Data Timeout and Auto Brightness are OFF
  2. Smart Mode - Data Timeout and Auto Brightness are ON with different settings during Peak and Off-Peak times of day. User can change various settings.
  3. Battery Saver Mode - Data Timeout and Auto Brightness are ON with settings to maximize battery savings. User cannot change the setting
May 24, 2011 | Motorola Mobility Defy Cell Phone
My battery got low and the low battery message
sometimes a very low battery will cause screen-freeze...once fully charged, remove the back cover and pull the battery out for 30 seconds and replace the batt and cover...the phone should power on.
Mar 29, 2010 | Cell Phones
Guages stop and irratic idle with dimming lights
what probley happened the alternator started to heat up alittle to much and caused the belt to spin on the pulley i would go ahead and get the alternator replaaced as soon as possible. as for the lights dimming and the gauges not working you was running off your battery making the vehicle mess up i would also get your battery checked while your at it.
Jun 09, 2009 | 1999 Mercury Cougar
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Nov 19, 2008 | Sony Ericsson K850i Mobile Phone
Motorola Mobility RAZR V3 Logo
70 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
