Question about Bulldog Remote Starter & T-Harness Kit for 99-03 Oldsmobile Alero; 97-99 Ol
Alero Jerking while accelerating
I drive a '99 Oldsmobile Alero and when I accelerate it is slightly delayed and jerks before it will finally accelerate. However it only does this at speeds lower that 50 MPH. Also when it is idling it will shake or **** still.
    New Friend:
Also check your plug cables for damage. My Jetta had a faulty throttle body and it did the same till I had a new one installed
Posted on Feb 07, 2013
  • 51 Answers
Have your plugs, coil housing, and coils checked...sounds like your engine is missing due to fouled plugs or a bad coil/coil housing
Posted on Jul 16, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Experience skipping and delay when i accelerate
Clean the throttle body and MAF sensor to start.
Jun 06, 2015 | Cars & Trucks
Jerking while idling and driving
The first thing you do is to have the fault codes checked with a scan tool.
Jul 14, 2017 | 2003 Hyundai Santa Fe
Jerking problem and engine shuts off while being driven
hi there.
A car that jerks when starting it, when accelerating or whilst you're driving is showing symptoms that something is wrong, though there can be many causes: it can be problems in the starting system, fuel, engine or the exhaust pipe. You may even notice that your car engine light has come on to warn you of a problem. Getting to the problem at the first symptoms can avoid more serious break-downs. In one HOWTO we'd like to give you some advice so you know all the possible reasons and answer your question: why is my car jerking?
Contents
  1. Car jerking caused by a blocked catalyst
  2. Jerking caused by a fault in the spark plug
  3. Car jerking because of a drained acceleration cable
  4. Car jerking because of dirty injectors
  5. Car jerking because of the motor winding
  6. Accumulated waste can cause the car to jerk
  7. Car pulling.
  8. Car jerking caused by a blocked catalyst Car jerking can be caused by a blocked catalyst, which leads to gases not being ejected as they should be. The result is that, until the car doesn't rev, the car jerks. If your car has a blocked catalyst you will also notice the following symptoms apart from the jerking.
    Symptoms
    • The 'Check engine' light will turn on
    • Your car jerks when accelerating
    • The car's fuel efficiency will have dropped
    For more extended information, take a look at our article on the symptoms of a blocked catalyst. The best you can do if your car is jerking due to a blocked catalyst is to visit a trusted mechanic to fix it.
    Jerking caused by a fault in the spark plug Another cause for jerking can also be a fault in the spark plug or one of its cables. You will know this is the case if your car jerks when you start it in the morning. The symptoms are very similar to a blocked catalyst, but if it's a problem with a spark plug, you'll notice the following too:
    Symptoms
    • The engine will make even more noise than it usually does, like that of an airplane.
    • It jerks when accelerating but also when you start the car
    In this case, you can solve the problem yourself by changing the spark plug. If you don't have the skills to change the spark plug yourself make sure a professional solves this problem.
    It is very important to keep the spark plug clean, so you can avoid car jerking and other more problems.
    Car jerking because of a drained acceleration cable A car jerking can also be a result of the acceleration cable being very worn out. You will notice because of the following symptoms apart from the jerking:
    Symptoms
    • Your car takes extra time to respond when you press the accelerator and starts jerking.
    • If you take a look inside, you will also notice that the outer covering of the acceleration cable will be damaged.
    The best you can do is change it as soon as possible, as the car will stop at any moment if you leave it to break. Take the vehicle to a mechanic to solve the problem. If your car has this problem, take a look at our article to know all the reasons why your car jerks when accelerating to find out what it may be or try adjusting the acceleration cable if you are handy with cars.
  9. Car jerking because of dirty injectors Another cause for car jerks are dirty injectors. This is not such a serious problem but should know it needs solving too. You will notice your car is jerking for this reason if:
    Symptoms
    • Your car also loses power
    • Your engine misfires frequently and jerks and stutters frequently and/or continuously while driving normally.
    It's best to clean them regularly to avoid costly reparations. You can do this yourself using a specific cleaning kit, which are quite cheap and can be found almost everywhere.
    Car jerking because of the motor winding The car's engine/motor winding can be another reason for car jerking. Wear of the engine's winding is most likely caused by the engine being put under stress - i.e. through hard acceleration.
    Symptoms
    • If your car has more than one winding and one of them is broken, the car will jerk.
    • In the case there's only one winding, the car will not start.
    The only way of knowing if this is the case is through the use of an Ohm meter, so if you don't own one it's best you check with a mechanic to know if this is the reason your car is jerking.
  10. Accumulated waste can cause the car to jerk Jerking can also mean the fuel filter is blocked because too much waste has accumulated. To make sure this is the case you can learn how to tell if your fuel filter is bad. If this is your case,go to your mechanics to solve the problem or you can also try to clean your fuel filter at home.
    These are the most common causes of a car jerking, however, your car could have another problem that needs the help of a specialist. If you're not sure of what is happening to your car it's better to bring it to a mechanic. The specialist will find the root of the problem.
  11. If you'd like to read similar articles to Why is my Car Jerking - All Possible Reasons, we recommend you browse around our Car Maintenance and Repair category.
Dec 14, 2017 | 2005 Chrysler Pacifica
Prado jerking while going up hill or jerking when accelerating
When was the last tune-up done? Should be done every 30-45KM, or depending on what your owner's manual maintenance book states.
1. Spark plugs
2. Spark plug wires
3. Fuel Filter
4. Air filter
5. Oxygen Sensor
If these have recently been replaced then do you have Check Engine Light (CEL)? If so, you'll need to get that checked by a mechanic.
GL,
Td
Oct 01, 2012 | 2000 Toyota Land Cruiser
I have a 2005 Chevy Uplander, and when driving on the highway at about 60-65, the van occasionally drops RPM's and when you press the gas harder, it recovers without any jerking or anything. The same...
This is a rare one and can be tricky. Since your rpm gauge rises back up when you increase your acceleration slightly but you feel no jerking of acceleration then this tells me that a speed/rpm senser either has a bad connecton or the sensor itself is going bad when the engine reaches an optimum heat while driveing on the highway. Since you feel no acceleration when you slightly press the accelerator down but yet the rpm gauge is increasing back to normal, the throttle body sensor may be compensating for the failed speed sensor/failed sensor connector. Please get your uplander diagnosed properly first to confim this.
Oct 18, 2010 | 2005 Chevrolet Uplander
I have a Jaguar 2L X type diesel, my problem is that the car has a slight jerking/juddering when driving. The engine management light is not illuminated and there seems to be plenty of power there when...
I have a Jaguar 2L X type diesel, my problem is that the carlb_icon1.png has a slight jerking/juddering when drivingicon1.png. The enginelb_icon1.png management light is not illuminated and there seems to be plenty of power there when accelerating.plz let me no a.s.a.p plz can you put pictures of the problems
Aug 31, 2009 | 2005 Jaguar X-Type
2004 Alero cutting out at acceleration
soundws like your on the right track change the filter if it still does it run a fuel pump volumn and pressure test? a scanner works well to help diagnosis these problems so get it scanned anyway some mechanical problems may not be far enough out of range to alert the ecm but enough to cause drivability issues?
Aug 26, 2009 | 2003 Oldsmobile Alero
My car is jerking while accelerating and reaching certain RPM
clean mass air flow sensor check for mil light
Jun 01, 2009 | 2002 Buick Century
I would look for a fault in the ignition system such as a cracked spark plug. Might need a scope check to put your finger on the problem
Apr 06, 2009 | 2002 Buick Century
Bulldog Remote Starter & T-Harness Kit for 99-03 Oldsmobile Alero; 97-99 Ol Logo
287 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
