Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
I have a 115 remington that runs, until the upper cover is on
I checked the usual ,eg. photo cell , igniter, not sure about the pressure setting, the problem is when i put the the shroud ( top hood ) over it . it dies, runs fine without the hood. any suggestions? thanks , jim
  • 92 Answers
I would say that it's definitly not getting enough air to fuel mix. Check all of your filters and the air supply line that gous from the motor to the fuel nozzle. They tend to get hot and brittle over time and even the smallest leak will shut the system down. Also check the high heat limit switch, it looks like a thick watch battery, take it off and hold a lighter under it, if you hear it click it's working, if not it's most likely the problem. There is no real way to check the CAD flame sensor, they can look fine and still be faulty.
Posted on Feb 03, 2009
My blood pressure is lower than usual I am a 84 female with chronic heart failure This morning my blood pressure reading was 123 over 61 Usually &; 115 over 62 What can I do ?
You must contact your doctor right away for this fluxuation. If they are not open I would call a 24 hour clinic and make sure it is ok to wait until the next day.
Feb 25, 2015 | Microlife Health & Beauty
Omron bp785 don't inflate above 115
find manual and check the procedure on how to adjust maximum maximum cuff pressure...
Oct 28, 2013 | Omron Bp785 10 Series Upper Arm Blood...
How do I set the Waterway Champion Pump for 115 Volts? I have the same problem, just installed and it runs for a bit then shuts off. It was mentioned that the pump is usually set for 230, so how do I set...
The voltage is not optional. What voltage are you plugging the pump into?
If you are plugging it into 115, the pump must be set for 115.
If you are plugging it into 230, the pump must be set for 230.
Usually there is a wiring diagram on the label on the pump body or if you remove the end cover, there may be instructions there. There may even be a switch or terminal that states 115 volts and another that states 230 volts.
Jun 29, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
The heater runs for approx. 7-10 minutes then shuts down
very rarely it's the circut board.most likely it will be the photo cell.does you photo cell have one blue wire and one white wire????or is it two blue wires,they are two differant photo cells.if it's two blue wires you nee to check the air's very important.if the pressure is wrong it will not work need a gauge to check it.
Mar 03, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy 115 will not ignite
1st check to see if you have spark, 2nd check the pump pressure using the correct pressure gauge, the pressure should be 5.1 psi for model 115. if little or no pressure you may have a air line leak or a defective rotor. if you do have pressure you may have a plugged nozzle. i hope this helps.
Jan 08, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton 175k heater
the air pressure is not correct on either units.the photo cell DOES NOT look for light any more,it count the light flashes.if the flame is not in the right possition the heater will shut down....after the unit ignites the ignitor is no longer used to keep the unit working,just the fuel that is being fed to the flame ball.that's why the pressure is so inportant.......
Jul 08, 2008 | Dayton E51 Oil Filled Utility Heater
Photo sms sending
Make sure it is using the right profile. Eg I come from New Zealand and use Vodafone. My MMS profile is called VFNZ PXT.
If you are sure it is using the right profile, check the profile settings eg the server and the GPRS settings. Also try sending a video (last resort) and if it works then you should call your service provider or try their website.
happy new year =)
Jan 04, 2008 | Sony Ericsson K610i Cellular Phone
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
263 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
