Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Garbage disposal won't work!
When I turn on the disposal, it makes a very slight buzz sound. The outlet does work when I plug another appliance in. There is nothing stuck in the blades of the disposal and when I put my hand down in the disposal and try to manually turn the blades, the right set turns fine, but the left set does not move at all. I ensured the red reset button was pressed in. When I use the disposal wrench under the disposal, it does not turn at all. Any suggestions?
    Problem Solver:
  • 6 Answers
Check to see if the cutting plate is free and will turn-be careful and be sure no one can turn the unit on while you are trying to turn the cutting plate-it is located in the drain hole that the food goes down. If it is locked up, hardware stores sell a special tool to break it loose. It should not be too expensive. If the blade is free, the motor is probably burned out.
Posted on Feb 03, 2009
Why my disposal won't turn off
Sounds like the disposal is plugged into the wrong outlet. Try moving to the other socket on the wall plate.
Aug 20, 2014 | Garbage Disposals
Badger 5-81 motor buzzing, blades spinning, won't grind
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
Jul 09, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Kenmore garbage disposal continuously running
make sure you have it plugged into the right outlet. Only one outlet out of the two is controlled by the switch. The other outlet is on all the time.
Dec 28, 2012 | Dishwashers
Garbage disposal won't work. It just makes a humming noise
might be something lodged in it, like a spoon or something. Turn it off and fish around in it with your hands.
May 01, 2012 | KitchenAid KCDB250G 1/2 HP Continuous-Feed...
When we switch on the garbage disposal, there's no sound at all..dead. Switched power cord to another outlet, plugged it in and automatically the motor turns on but the blades don't move. It doesn't...
If you plug it into the original outlet under the sink and flip the switch, nothing happens? No motor sound? And when you plug it into a different outlet, you can hear the motor, but the blades don't turn?
If this is the situation, I would guess that there's a problem with the insinkerator. Something stuck in it, or it's otherwise jammed. This could have tripped a breaker.
If the breaker failed or the circuit wasn't wired properly, this jammed condition could also have resulted in the wire at the switch or under-sink receptacle burning off of the terminals.
Turn off the circuit at the panel, double check that it's off, and remove the switch and the receptacle to see if the wires are still connected. If they've burned off, do not re-connect them. You should consult a licensed electrician to correct a hazardous situation.
Mar 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
There is a buzzing sound, but the blades are not turning.
SOUNDS LIKE MOTOR MAY BE BURNED OUT.
IF SO, U CAN TURN BY HAND, BUT MOTOR
WINDINGS MAY BE FRIED SO IT WON.T RUN.
U MAY HAVE TO REPLACE. SEE IF U CAN
SMELL FOR BURNED WINDINGS.
Jun 20, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
700 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
