Question about Logitech Cordless Desktop EX110
Mouse left click does not work
All of a sudden my mouse's left click did not work. all the other functions on the mouse work fine. i replaced the batteries, i looked at the circuit and it was fine. the keyboard works. everything works except for the left click function on the mouse. any suggestions?
  • storkl Feb 04, 2009
    Same thing here - sometimes it clics sometimes it doesnt sometimes it doubleclics...
    Sergeant:
  • 270 Answers
It may be the internal problem.try to replace it.
Posted on Feb 03, 2009
The left click is not functioning, right click works just fine but left click has no response whatsoever.
Usually either the lever (button) has slipped out of it's pivot point, the spring has come out, or the switch below the button is broken. To check, look around the edges for a small screwdriver slot or small screw. Open the mouse. Look at the button to see how it pivots. If on opening there are small pieces of plastic, discard the mouse. if it has just slipped out of its spot, realign and close the mouse, it should be good to go.
Mar 22, 2015 | Logitech LX3 Optical Wired USB Mouse Grey
Mouse clicker buttons not working
In Control Panel there is a mouse section, you may have the clicking disabled. if you don't and it still isn't functioning then you have a bad touchpad and it will need to be replaced.
You can also test using a USB mouse to find out if you have clicking disabled.
Feb 26, 2013 | Computers & Internet
Left click does not work. Both on touchpad and external mouse.
This indicates a virus in your system, since you can't use the mouse, I would do a full recovery to factory setting if possible.
May 11, 2012 | Lenovo ThinkPad T500 Notebook
The right button suddenly stopped working. I made sure the settings are correct under configuration, but it still will not work. I can use two fingers to do a right click function on the track pad. The...
check it on some other pc ... if the problem is still the same then u need an replacement, if out of warranty , then open the mouse, remove the button and get a new one of the same kind and fix it... u need a solder iron to do that bro remember :)
Jan 11, 2010 | Logitech Cordless Mouse
Mouse not working at all and need help with the BIOS & how to make my mouse work
Left click start. Left click control panel. In Vista find Hardware and Sound and left click on mouse. You should get a window which allows you to set mouse functions. In XL Left click start. Left click control panel. A window should open listing various computer systems. Left click on mouse. You should get a window which allows you to set mouse functions. If you don't see mouse symbol or word, make sure the mouse software is installed. This should work. You can check on the mouse software by going to Device Manager and checking Input Devices. To do this go to Control Panel as directed above. Left click start. Left click Hardware and Sound. Find Device Manager and left click. Then, find Input Devices.
May 21, 2009 | Acer Aspire 5315 Notebook
Right click doesn't work
HI,
REALLY DEPENDS ON THE AGE OF THE MOUSE AND HOW OFTEN YOU USE THE RIGHT CLICK FEATURE. LIKE MYSELF I USE IT CONSTANTLY. UNFORTUNATLEY IF THE RIGHT CLICK NO LONGER FUNCTIONS AND YOU USE THE MOUSE ALOT LIKE ME THE MOUSE IS SIMILAR TO A KEYBOARD IN THAT IT HAS ONLY SO MANY TACTILE TOUCHES BEFORE IT HAS WORN ITSELF OUT. YOU CAN HOWEVER GO TO CONTROL PANEL IN YOUR OP SYSTEM UNDER MOUSE ETC AND DIAGNOSE A SOFTWARE INCOMPATIBILITY BY RECALIBRATING THE MOUSE. IF THIS DOES NOT WORK IT IS MOST LIKELY TIME FOR A NEW MOUSE.
GOOD LUCK, HOPE THIS HELPED!
Mar 30, 2009 | Computers & Internet
Magnifier doesn't work
Try going to Control Panel and click on the mouse icon. Then the mouse properties will appear showing the mouse. In the left column,move your cursor over the right side button click on the drop down and select magnify. Hopefully it will now work.
I had to move the magnify function to the left button because it was to sensitive on the right.
Nov 27, 2008 | Microsoft Wireless Laser Mouse 5000
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Logitech Cordless Desktop EX110 Logo
327 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
