What is the effect of increasing the angel between two vectors to be added on magnitude of their resultant?
Resultant of addition of two vectors A and B is calculated as the square root of (square of A + square of B + 2AB cosx) where x is the angle between the two vectors.
If the angle between the vectors increases, we need to keep in mind the behaviour of cos for different values of x. The resultant be maximum for x=0 and continue to decrease till x=180 but will again increase to a max value for x=360; the same as for x=0.
Posted on Feb 12, 2009
Two forces of 5 N and 12 N respectively act on the same point. show how you would determine the magnitude of the resultant by using the tail-to-head and tail-to-tail methods and pythagoras theromen (13 N)
Draw a vector of length five. From the head of it, draw another vector of length twelve. Now measure the distance from the tail of the first vector to the head of the second.
If the two vectors are at right angles then Pythagoras' theorem applies. Square five to get 25. Square twelve to get 144. Add them to get 169. Take the square root to get 13.
Jan 24, 2014 | USAF Security Forces Shield Decal
What is sum in math
The sum is the result of adding two or more things together. The things don't have to be numbers, they can be vectors, matrices, polynomials, or other things.
For the other part of your question, the sum of 838 and 2 is 840.
Jan 19, 2014 | Computers & Internet
Final Given that Force 1 = 35 pounds and Force 2 = 120 pounds, find the angle between the forces if the magnitude of the resultant force is 140 pounds. Round answer to the nearest degree. (a)62...
You do have many math questions. If you expect us to do your homework for you, you should post under an appropriate category. I started this morning answering this question with time-consuming diagrams but did not finish and did not post the answer. During the day I tried to locate your question but for the longest time could not until I launched an all Google search over the Internet and found it. Why should anybody go through all this grief to help you? Well I just did not want my previous work to go to waste.
I hope it helps somebody.
OACB is a parallelogram. R is the resultant.
Use the cosine law in the triangle OAC
R^2=(F_1)^2+(F_2)^2 -2(F_1)(F_2) cos (angle OAC)
Replace the variables by their known values and reduce your equation to cos (angle OAC) =-53/112. Solve for angle OAC in degrees
angle OAC =arccos(-53/112). The angle between the two vectors is the supplementary of angle OAC
Dec 05, 2013 | Western Digital My Book Essential Edition...
Vectors in two dimension,how do i approach them?
Just add the three vectors together. The first vector is 0.0i + 4.0j . The second vector is about 1.4i - 1.4j . The third is about -0.7i - 0.7j .
Adding the three vectors together gives about 0.7i + 1.9j .The exact answer is sqrt(0.5)i + (4.0-3sqrt(0.5))j .
Mar 15, 2013 | Camping, Backpacking & Hiking
What is the magnitude of a vector with components (15m , 8m )?
try using my ole favorite alt="image3.png"> its a little variation of Pythagorean theorem but its allways worked for me
Mar 05, 2013 | K'nex Education Roller Coaster Physics...
New york city is 200km and in the direction N48W from los angeles. monaco is 80km and in direction S72E from los angeles. find (a) the distance of monaco from New york city. (b) the bearing of new york...
This has a lot to do with vectors and pythagoras, try drawing each line and their direction then try to make right triangles and solve with pythagoras.
Hope this helps
Mar 05, 2011 | Computers & Internet
Is there an easy way to use vector mode to find the magnitude of a vector? I know you can just take the square root of the sum of the component squares, but it would be nice to have a shortcut.
If you're dealing with complex numbers, simply switch the view to polar coordinates. The length of the vector is the magnitude of the number. SHIFT MODE down-arrow 3 allows you to select between polar and rectangular coordinates.
Oct 07, 2010 | Casio FX-115ES Scientific Calculator
I initiated an adwords campaign on Sept 7th and got reasonable results for 4 days, impressions and clicks (100 + per day). On Sept 12 the tracking showed both impressions and clicks went to almost zero and...
Please check that the keywords mentioned are relevant to those in your campaign, Google adwords will ban the ads if the landing page, keywords and campaign does not match.
Sep 15, 2009 | Google AdWords
Two vectors, 10 and 15 units long, make 60 degrees with each other. Find the magnitude and direction of their resultant with respect to the longer vectors.
A(the longer vector=15units) will have the components on x and y axis. (x=15, y=0)
B(the shortest vector=10units) will have the components(x=5,y=5/sqrt(3))
R = A+B (the sum vector) will have the components (x=20, y=5*sqrt(3)), thus the length of R is 5*sqrt(19) and the angle with respect to A is 23.41deg or arctan(5*sqrt(3)/20) rad. = arctan(sqrt(3)/4)~0.40rad.
Jul 11, 2009 | Darda Race Track Physics _
VECTORS
Your Question :
My Answer ::
In scalar multiplication we are considering only logical values and doing multiplication but here we are taking care of the direction of the force magnitude of the force applied to the body for the perfect accurate value which helps in making of the real world application.
here scalar values will not work for making any real thing, So in your question cos (a,b) suggests the resultant direction of the resultant force and |a||b| are the magnitude.
For more details on vector multiplication :: http://mathworld.wolfram.com/VectorMultiplication.html
Sep 20, 2008 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
