Question about Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range
My whirlpool GS465lels oven will not light.
I can smell the gas and hear the "ticking" of the, what i assume is some type of igniter switch.
Is this a quick fix or do i need a rpl part?
  • Whirlpool Master
  • 4,655 Answers
Here are some You Tube videos that offers solutions. No easy fix Please use care. Let me know if this helped you JT
Posted on Feb 03, 2009
I hav whirlpool accubake.oven wont stay ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
The fan is working bt the oven isnt getting hot
I assume you have already checked the gas supply by turning on a burner on top.
Do you smell gas when the oven first tries to light? If the flame sensor isn't picking up a fire on the oven burner within a few seconds after the igniter is supposed to start firing, it will shut off the gas valve. The first thing to check is the oven igniter. Can you hear it sparking (repeated snapping sound until main flame starts)? The sound may be drowned out by the fan, so hearing it would only verify that it's making sparks; not hearing it doesn't tell you anything unless you were able to hear it before the problem started. If you had a major spill in the oven recently, it's possible some residue made its way to the igniter or pilot flame tube and is gumming up the works.
The next items to check would be the oven gas valve and thermostat.
Nov 12, 2010 | DeLonghi DEFSGG36 Gas Kitchen Range
I have GS465LELS that displays LOC when the clock is displayed and in the error display mode shows E4 F3. The sensor was checked and tested fine, it was even replaced and still gave the error code. What...
The F3 - E4 means Oven temperature sensor (RTD) opened (lower oven, if double oven) and is suggested to
Replace Oven temperature sensor (RTD)
Also your control board is composed from two separate parts which are both very expensive.
One part is the electronic control with pads and clock CNTRL-ELEC
Number: AP4433850 made by WHIRLPOOL
And behind this is the power supply pca Power supply, pca
Part Number: AP3135669 made by WHIRLPOOL.
The part which becomes usually overheated is the power supply due to the presence of the transformer on it. So you need to visual check both above parts before proceeding with any replacement to be sure which is the one that have been over heated.
Here is the link with all above parts and also indicated the prices just to have a reference.
Oct 31, 2010 | Whirlpool GS465LELS Dual Fuel (Electric...
I have a Whirlpool Accubake gas stove Model SF362LXSQ. Range top is working fine Oven will not ignite. No gas smell even. When I set the oven to start I can hear the click and see the spark sometimes, but...
Iquitous, we're sorry to learn of your Oven concerns. We would like to discuss this further with you. Please email us at at your earliest convenience with your name, address, a phone number and best time to reach you along with your model and serial number.
Oct 26, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Oven Will not light
most of the time this will happen when you have a weak oven igniter.but if you smell alot of gas you should turn off the gas and call for service.good luck!
Jan 23, 2010 | Whirlpool SF367 Gas Kitchen Range
I have a whirlpool oven model #sf368lepw. The stovetop burners will light but the oven will not light. The igniter is working and I can hear and smell gas flowing but it wll not light. What do I need to...
you need to look at the igniter and see if it is orange. the ignitor or glow coil as it can also be called, needs to glow white hot in order for the oven to ignite. when it gets orange it needs to be replaced. hope this helps.
Oct 13, 2009 | Ovens
Oven makes a clicking sound after it has been baking for 2-3 hours.
Dear Robbird:
You need to give more detail---- brand. model, age, gas or electric, speed or repetitiveness of the sound; is it a click or a tick sound ? I will assume it is gas. Is the sound the same as when you start a top burner and you hear the tick as it is lighting? Or, is it a click the is slower and you hear it from somewhere inside the oven ? It could be the metal body expanding as the outer parts of the oven get hotter with long hour usage. I n the is case, there is nothing to do or to worry about. Does the sound stop when you turn off the oven or does it continue for a while. Naybe you can resubmit with better info to get a more precise diagnosis. Wait to hear from you, Macgivor.
Oct 04, 2009 | Five Star TTN280 Gas Kitchen Range
Oven control, possibly thermostat or oven selector switch
my dacor ER36G oven will not ignite. The top range works perfectly. When I turn on the oven, I don't even hear the gas or the ignition sequence as I used to. The heat preset light just blinks and the oven will not engage. I have reset the circuit breakers just in case, but nothing works.
Dec 07, 2008 | Whirlpool Kitchen Ranges
Magic Chef Gas Range
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
Jul 29, 2007 | Magic Chef CGR1110 Gas Kitchen Range
Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range Logo
290 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
