Question about RCA D52W19 52" Rear Projection Television
Will not fully come up.
RCA MOD# HD61W66 / chassis# ITC222A
The TV was turning on intermittently. Now it only attempts to turn on but shuts down immediately.
  • rayo2 Feb 03, 2009
    does the mod# HD61W66 have the same chassis as the mod# D52W19B?
    President:
  • RCA Master
  • 1,779 Answers
2200mfd cap on the HV Power Supply board about mid way on the chassis, if it is bulged at the top, REPLACE IT.....Let me know! Also, cold solder joints on same...
Posted on Feb 14, 2009
Rca Tv wont power on HD61W66
Sounds like the capacitors on the deflection power board CP150, CP120 and CP114 they are famous for failing in all versions of the ITC222 chassis. You can get the repair kit by that same name from www.tvrepairworld.com the kit has the caps and the cd with repair instructions
May 18, 2012 | RCA HD61W66 61" Projection HDTV
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
I need to convergence my tv but I dont see it on
Very easy repair. You can install the repair kit called the ITC222 and ITC222A convergence option missing repair kit. Its available from www.tvrepairworld.com and it contains the parts and the CD with instructions.
May 31, 2010 | RCA HD61W66 61" Projection HDTV
My setup menu doesn't have a Auto Convergence. TV showing out of alignment.
Very easy and inexspensive repair. You can get the repair kit called "ITC222 and ITC222A convergence option missing repair Kit" From www.tvrepairworld.com which has the parts and the CD with instructions.
Jan 12, 2010 | RCA HD61W66 61" Projection HDTV
Television will not powwer on
Hello al1895,
This model of TV uses the ITC222A chassis. This is a common problem in this unit. The problem is usually centered around 4 capacitors (CP140, CP150, CP110, and CP114) They usually vent (becom bloated or puffy) and develop an internal short which causes the TV to shut down. This is usually caused by power surges (even when connected to a surge protector). The repair for this problem does not cost much, and I would suggest that you have a TV repair technician examine this TV due to the other problems that can happen with this chassis (ITC222A).
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Mar 13, 2009 | RCA R52WM24 52" HDTV Projection Television
Intermittent audio...picture fine
Does this model have a headphone jack? If so, plug a pair of headphones or external speaker into the jack, turn the volume to an acceptable listening level and see if the problem goes away. If so, the headphone jack may be bad.
Mar 02, 2009 | RCA E09344 Under Counter Kitchen TV 9"...
RCA P52920BL
F32 or F36650 = same transformer = 257805 or Asti 2078
P52920BL = need service number = P52920BLXXX then I will
confirm flyback part #..................................T.
Dec 26, 2007 | RCA F36650 36" TV
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
109 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
