Question about Jensen AM/FM/MP3/DVD/CD iPod-Ready Receiver w/ 7" Motorized LCD Screen Car Video Player
Jensen vm9312 SRC light is red but nothing else.
It blew the radio fuse I replaced it now nothing on the radio. I wired it up properly as far as speakers and power. I have not hooked up the brake or reverse wires i have no idea how to. I just wired it to my plug for my wiring harness in my 98 F 150
SOURCE: how do i do to bypass my jensen vm9312
go to www.ecoustics.com then click on forum at top click car audio then multimidea. and read Teir are bypass codes for several models here.just have to look for them.
Posted on Dec 18, 2007
Shuttle83
  • 1139 Answers
SOURCE: Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Posted on Sep 21, 2007
Benimur
  • 6966 Answers
SOURCE: jensen uv8 wiring issues
The wires you posted need not go anywhere not unless you have a device that will attached to them.
antenna power - connects to the motor of a telescopic external car antenna. When you power on the unit, it will automatically raise the antenna;
amp power - connects to an add-on/external amplifier. This switches/triggers the amp to gon when the Jensen is powered up;
reverse - attaches to the reverse light of your vehicle. This will tell your unit that you are reversing and will activate a rear view camera.
As earlier stated, if you do not have any use of these devices then there is no need to connect the above described wires to anything. Connecting them to the ground would have a bad effect on the internal circuitry of the Jensen since they are meant to supply power and therefore are connected to the B+supply when the Jensen is powered except for the reverse which would sense a 12V from the vehicle's transmission. Connecting them to the constant B+12 would have no ill effect except that your Jensen would always be on.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
good luck and kind regards.
Posted on Nov 20, 2007
SOURCE: JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
Posted on Mar 20, 2008
SOURCE: vm 9410
go to a audio local seller and ask them if they have one they should be able to get you one
Posted on Oct 10, 2008
I have a 1997 grand marques that when I replaced a fuse it blew everything in the car far as lights radio brake light head lights etc.
the fuse connected the circuit that was faulty and probably blew again
check the fuse and find where the wiring is dead shorting to ground
Jun 17, 2016 | 1997 Mercury Grand Marquis
I lost my horn and speakers on a 2010 road glide anyone know where to look
did you recently change the deck unit stereo somthing in the wireing there or maybe you blew a fuse if you tryed to hook somthing up recently maybe over loaded the fuse and just blew the fuse usually its around the seat or under the gas tank or on the front forks under the lights check the fuse first replace it if it happens again you have somthing over loading it
Feb 25, 2012 | Harley Davidson FXR Super Glide...
Tryin to hook up jensen vn9312 to a gmc 2001 yukon. the sourse light lights up but nothing responds
I am having the same problem. I sent it for repair and they said it works fine. online everyone said it might be a parking brake or grounding issue. If i find out ill post it
Sep 18, 2011 | Jensen's VM9312 Car DVD Player
Radio was working great today, then bam it quit. Checked the fuse found it blew(10amp) replaced it. Tried to power up the radio NOTHING... Checked ground wiring,it's fine, checked two other fuses fine....
If you already have your dash apart, have you looked for a fuse directly on the radio itself? There should be one somewhere near the power wiring on the back of it. If this is blown, you will be getting power to the wiring, but not to the radio. Replacing this fuse should help you out.
If this is not the problem, use a voltmeter to check the wiring where it goes into your stereo. If there is no power here, then the power overload that blew your 10amp fuse is probably related to a short circuit somewhere in the wiring between the fuse and the stereo. To repair this, you will likely have to run a few new power wires (you should replace both the positive and negative to make sure you have fully bypassed the problem) from the fuse to the stereo. If you have checked these wires with a voltmeter and they have power at the back of the stereo, but the stereo itself is not still not working, then the problem is with the stereo itself.
If you find that the wiring to the stereo all has power ... the fuses are all good (which you have already stated) ... the fuse on the stereo itself is in good shape ... then there might be a short within the workings of the stereo itself. If you are not experienced with repairing electronics this could be out of your ability to fix -- you can bring it to a shop or buy a replacement. If you are experienced with repairing electronics, open up the stereo and start checking the wiring (starting from the closest point to the power input and moving towards the stereo's face. This could be a long and arduous process ... so if you are not experienced with it ... I recommend taking it to a professional or just replacing it (your hair is probably worth more than the $100 you would spend on a decent replacement stereo ... and if you are like me, you would be ripping out your hair after checking the first few hundred possible connections within the stereo itself).
Hopefully it is just the fuse on the back of the stereo itself, and you can have that fixed in short order. Good luck!
Jun 07, 2011 | Car Audio & Video
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
The radio will no turn on. we have all the wires connected the power cord is plugged in but when we press and or hold the mode button nothing happens. its a new radio that we are installing that was bought...
If it is a new radio first make sure your power wire is actually hot. Use a multi meter. Also you may have a blown fuse in the fuse panel. Check that. Make sure it is grounded as well. Improper ground will make it not power on as well. For this radio Blue = Remote that you run to your amp or power antenna. Insulate it if you are not using either. Black is Ground. Red = Your accessory wire and should only get 12 volts when the key is turned on (switched 12 volt source.) Yellow is your continuous power source. Hook this to your battery or other suitable continuous 12 volt power source. It also has a 5 amp fuse inline. Make sure it did not blow. Replace it to be absolutely sure. Use another 5 amp fuse. Never go higher. The other wires are for speaker hook up. If you do all this and still no power. You may have a faulty radio. Good luck.
Mar 06, 2011 | Car Audio & Video
Radio will no longer flip out. Only after resetting car system
you have a bad drive gear, it may cost more to fix then getting a new unit, sorry
May 12, 2010 | Jensen's VM9312 Car DVD Player
Car Audio & Video Logo
139 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
