Question about Dryers
We have a Maytag dependable care electric dryer that does not seem to operate properly on the regular setting? The other 2 settings seem to operate OK. The regular setting which would be the top setting seems to not give off the same heat as on medium? help Darren
  • 979 Answers
That control knob may be the culprit. The wiring could be faulty there and needs looking at. The connection from within the switch may not be very clean (good contact).
Posted on Feb 04, 2009
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
Dryer gets too hot on regular laundry setting but seems to work ok on delicate laundry setting.All vents and filters are clean.When using regular setting when drying is done the clothes are too hot to...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 06, 2011 | Danby DCD5505W Electric Dryer
My Maytag "Dependable Care" dryer timer is not functioning and the dryer will not work. Will simply replacing the timer fix the problem? The washer/dryer set has been wonderful, but is about 12yrs old. ...
Don';t throw the dryer away yet. Check the circuit breaker in the electric panel to see it it has popped. If it checks out ok then check where you plug the dryer electric cord in. There may be an overload pop-out button on the receptacle. If there is, reset it.
Oct 09, 2010 | Maytag Clothes Dryer Almond Timer Knob...
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Dryer seems to be operating properly, it heats up, but the clothes aren't getting dry. I noticed the lint collector isn't collecting much lint, is it possibly the blower?
Could be a stripped blower wheel. Remove the front panel. Rotate the blower wheel and look for loose movement on the motor shaft. If that does not work,turn the dryer on with a NO HEAT setting and run it. See if the blower wheel is slipping. If the blower is OK,check the exhaust vent for blockage.
Sep 24, 2009 | Maytag PYE2300AY Electric Dryer
Problems with Maytag PYE4558A not heating properly
Call the dealer, tell them to come and fix the dryer or take it back to their store, whichever they want. If they give you a hassle tell them you are going to call the Better Business Bureau and the State Attorney General.
Jan 04, 2009 | Maytag PYE4558A Electric Dryer
Maytag Electric Dryer Atlantis MDE7600AY
sounds like you have a restricted vent . check not only the hose but also the house venting. usually clogged at the screen or flapper outside. another ppular place for a buildup is the inlet under the lint screen. without proper airflow lint collects on element. take care of the quickly as it could lead to a fire.
Feb 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
