Question about Casio Parts Cash Register PC Desktop
Unable to program
I bought this register used when I turned it on it has LLLLLLLLLLLLLL I cleared it now it is showing P1 & 0 on the display when I turn the tp program position it takes the numbers on the keypad & clear them. However, it does not show it is taking the programing. Any help please, when I trun the power switch off & back to on it shows LLLLLLLLLLLL again.
  • 2 more comments
  • al khalil Feb 03, 2009
    In addition, Iam trying to program the machine since nothing in it. It is prints initializing report at the start, but if I press NoSale for instance It does not open the drawer. If I turn the key to programing and follow the manual it does shows P1 0 on the display when I punch ex 1234567890 it display it & clear key will clear but following the programing steps not working for ex after I progam date & time the new date & time do not show. As far as battary the manual does not say anything about battary if there is let me know where is it. Thanks
    I checked all keys it is fine.
    it is Casio TK-6500
  • Kim Tyler May 11, 2010
    check your keyboard, you might have a key stuck
  • 737 Answers
Hi. You have battery failure and you have lost everything. If it is a powerful machine, it may require a lot of system programming. Do not put any user programming into it until it has had a battery and system settings performed by a dealer.
Mark
Posted on Feb 03, 2009
  • flexion1
    flexion1 Feb 03, 2009
    The battery is either soldered to the main board or plugged into it. On some low end models, there are AA batteries in the printer compartment. Since you have not told me which Casio you have, I can't be more specific. Your manual will not tell you how to repair your machine, as it is not a service manual - these are held by dealers since there is a risk of electrocution or severe damage if the user attempts these repairs.
  • flexion1
    flexion1 Feb 04, 2009
    The 6500 uses a special Vanadium Pentoxide Lithium battery inside the machine. It must have the correct battery or it will lose the programming every time the power is turned off (Also risk of explosion due to charge system). If the previous owner had the battery changed on time (three to five years), then you would only have a few things to program. This model is complicated to setup as it uses dynamic memory allocation wich must be set before all other system options. Take it to a dealer and they can do it all for you. If you want to save money, just ask them to do the system programming, then you can do the rest from your manual.
I have a Royal 9155SC register. The display shows 0.00 and no key is working with continuous beeping. Please help.
Half Sysem Clear
a. Turn the key to the "PRG" position.
b. Unplug the cash register from the power source (pause
for 10 seconds) and replug the cash register.
c. Continue with normal operations.
Full System Clear
!!! THIS WILL ERASE ALL PROGRAMMING AND DATA!!!
a. Turn the key to the "PRG" Position.
b. Unplug the cash register from the power source and wait
at least 15 seconds.
c. While holding down the [CLEAR] key, replug the cash
register.
d. Re-program the cash register.
e. Continue with normal operations.
Oct 28, 2014 | Royal Office Equipment & Supplies
Samsung 5200m clear grand total
I HAVE BOUGHT A USED ER5200M. I HAVE CLEARD THE PLU'S AND RE PROGRAMMD WITH MY ITEM & PRICE INTO THE PLU'S. EACH NIGHT AFTER I DO "Z" REPORT, THE REGISTER IS STILL TOTALING MY GRAND TOTAL ONTO THE OTHER OWNERS GRAND TOTAL WITH MINE, HOW DO I CLEAR GRAND TOTAL SO IT WILL BE ONLY MY GRAND TOTAL ?
Apr 19, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
In my casio te-2400 cash register after doing the fc reset, it displays p1, what do you from this point?
If you have that on the display, the FC reset was successful. it should have printed out a receipt at the same time. Now you turn the key back to REG and the lockup that you were trying to clear should be gone.
If anyone needs a manual for a Casio TE-2400, the programming manual is here:http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Oct 23, 2011 | Casio Parts Cash Register PC Desktop
TEC MA-1650 Cash Register It appears the register has been put into a sub programming mode somehow and we are unable to get register functional again. When Register is switched to Set there is a P...
Perform a status clear.
turn key to blind(must be S key not mgr key) while holding zero key down turn reg on with power switch on right side.
reg will beep once & print reciept saying status clear.
this wil not clear programs or totals.
Dec 12, 2010 | Office Equipment & Supplies
I had posted this problem once before hopefully get assisted this time. I purchased a casio TE-4500F register with scanner I had to reinitialise it to clear old data, and reset it now the scanner red light...
Hi. This is normal. Unless you made a backup, you will have lost a lot of system programming. Firstly you must make sure you have initialised it with the code for scanning and not check tracking. To do this:
Turn key to program mode 5 SUBTOTAL SUBTOTAL
This will print the memory allocation. Next to file 16, you should see a figure in the thousands (usually 6000).
Next you need to allocate the I/O port for the scanner. Try this:
Turn key to program mode 3 SUBTOTAL 298 SUBTOTAL 2000 CASH SUBTOTAL
Now perform a flag clear to set the new I/O:
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL.
Turn back to REG mode and try it. You might have to log a clerk back on after the flag clear. See how you get on.
Dec 29, 2009 | Casio Parts Cash Register PC Desktop
CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.- Press the number 10801 and then press SUBTOTAL. Initialisation is completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
May 12, 2009 | Casio Parts Cash Register PC Desktop
Casio tk 3200 cash register as stoped responding
Hi.
Try a flag clear:
Press SUBTOTAL.
Now turn key back REG mode and try it.
May 08, 2009 | Casio Parts Cash Register PC Desktop
Casio te-2200 set up!
Hi.
Yes, that's the problem alright. you said it in the first sentence. It hasn't been used for a while. Therefore, no one would have replaced the batteries as they weakend from sitting, so now you have memory corruption which means you have lost everything from the machine. It must be fully RAM cleared and re-programmed. I hope you have a backup, or there may be a lot of work ahead. If your dealer programmed it originally, they will probably have a backup of your prog to dump into it.
Mark
Oct 26, 2008 | Casio Parts Cash Register PC Desktop
Casio CE-3700 cash register MAC instructions
Hi. I would advise both of you to try a flag clear first to see if you have any program left.
Turn key to program. Power off at wall.
Hold RECEIPT FEED, and turn power on at wall.
Wait 10 seconds, then let go of RECEIPT FEED.
When you see 'FFFFFFFFF' press SUBTOTAL.
Turn key back to REG and try it.
If you still need help, let me know.
Mark
Apr 15, 2008 | Casio Parts Cash Register PC Desktop
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Casio Parts Cash Register PC Desktop Logo
148 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
