Question about Olympus IS-500 35mm SLR Camera
Zoom the zoom mechanism is not working properly
  • Print Mama May 11, 2010
    Can you please explain what it is or isn't doing? Like noise moving in and out etc?
  • 538 Answers
Yes, Zoom Drive Assembly gears are broken.
Common problem.
Needs service
Posted on Apr 02, 2009
Is not working properly
A good possibility is the zoom head is causing the clicking sound. As we zoom the flash, the inside of the head moves to the back and forward. Gently tap it a few times see if that helps. My guess is it needs servicing.
Apr 18, 2014 | Canon SPEEDLITE 580EX TTL Flash
I have a fujifilm finepix a350 the lens will only open a little ways and it won't zoom I get a zoom error.
Have you ever touched to the lens of the camera before? Generally it happens after someone have mistakenly touched the lens.
The lens mechanism works on its groove. Sometimes dust or broken particules drop in it and the mechanism will not work properly at that time.
Also this mechanism sometimes accidetally has been broken by forcing on the lens. So it is better to be disassebled the camera lens mechanism to see what happened. If it needs to be changed any part then it means that much money you will pay. But generally, there is no need to change any part if you did not drop the camera or forced the lens with a great power. So there is only thing you have to do is to be disjoined and see. If you have any exprience to repair something , then you may do it yourself as well. Do not worry to unscrew the camera. But please do it gently and slowly. Be careful while doing it.
Regards.
Apr 26, 2010 | Cameras
Camera is starting, but i touch the lend zoom from moving out
If you cycle it, power off and back on and the lens comes out properly, don't be concerned, if it doesn't come out right, it has been damaged and will require professional repair. They have tiny plastic gears and electric motors which can jam or break in the lens mechanism
Apr 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Olympus zukio 14-45mm lens does not auto focus or zoom not sure if it hit anything after the last shoot
does not do focus/zoom properly,is due to defective mechanism of the lens unit,so get it serviced.
Mar 29, 2010 | Olympus EVOLT E-500 Digital Camera
Sony lens 18 - 70 got stuck and it is unable to zoom
Due to the tight tolerances inside the lense mechanism - small bits of sand or lint may become trapped in the mechanics.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned.
There are many small parts and intricacies that will render it totally useless if not done properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 29, 2010 | Sony Alpha DSLR-A200K Digital Camera
The zoom lever is not working moves but doesnt change
If the zoom lever is not working then I would recommend buying a new pair without a zooming mechanism. Zoom binoculars are more trouble than they are worth. Sorry!
Feb 20, 2010 | Minolta Classic II Binocular
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
My Nikkor 70-300mm lens will not zoom
First thing: Don't try to zoom it at all anymore. The mechanism inside is broken or somehow disconnected, and you can make it worse by trying. Please take it in for repairs as a camera pro will need to look at it.
Mar 19, 2009 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Zoom Error
We had the same problem with a Fuji FinePix s3000 purchased almost three years ago. Its been a terrific camera and has worked perfectly until just last week when it came up with the "Zoom Error!" problem in the view finder. Since then we have not been able to take a single photo. We did not expose it to any extremes of heat or cold and we did not get it wet, so that would not explain the failure. I very carefully took the camera apart with a jewler's screwdriver and found that it is quite complex inside. To get to the zoom mechanism you have to remove 3 layers of circuit boards. Upon inspecting the zoom mechanism and the minature gear box I could find nothing obviously wrong or broken. Incidentally, don't try what some people suggest for other Fuji cameras about manually pulling the zoom out because you'll probably just strip the gear box. The mechanism is driven by a small motor about the size of a thumb-nail. I guess its possible that this had failed, but since I was not sure of the voltage and I didn't want to disconnect it, I didn't test it to see if it worked. I checked to see if there was any sand or grit in the mechanism but it all looked clean. When I put it back together the zoom mechanism extended and stayed there. The screen still showed "Zoom error". The only solution I can see is to buy a new camera of some sort. It seems that many of the Fuji cameras suffer from this zoom error problem so maybe a change of brand is in order. I think Fuji need to redesign their zoom mechanism.
Sep 12, 2005 | Fuji FinePix S3000 Digital Camera
Olympus IS-500 35mm SLR Camera Logo
87 people viewed this question
Top Olympus Photography Experts
pontelemon
pontelemon
Steve
Are you an Olympus Photography Expert? Answer questions, earn points and help others
