Question about Car Audio & Video
I have no sound from my speakers. my battery ran down and i had to put radio code in now i have no sound
    New Friend:
  • 101 Answers
Did you check your fuses?aftermarket radio?dos radio power on?
Posted on Feb 03, 2009
What is the color code for a mercury villager radio
use a volt meter to find b+ and b switched then take a nine volt battery or cordless drill battery take other wires in hand put one on one side of battery the sequencing touch others till a speaker makes a slight pop sound then you have the two that run to that speaker repeat till you have figured out which wires run to which speaker
Mar 04, 2013 | Cars & Trucks
Where are the fuses for 1993 honda accord
You need the radio security code.
Jan 29, 2013 | 1993 Honda Accord
The battery ran down and after it was recharged the radio would not work. The word "Code" comes on, I have the 4 digit code. Is their a special sequence or additional buttons that need to be...
after you put in the code for the radio try turning the radio on by hitting the power button. there might also be an eneter button that you can push as well.
Nov 20, 2010 | Acura RL Cars & Trucks
I have a 2000 cadillac sls. Battery ran down, can't use radio&CD
Try disconnecting your battery for 10 minutes to reset the radio and factory amp. Disconnect negative terminal only and avoid touching your 8mm wrench to the positive post(s). Read the warnings on top of the battery about smoking and open flames and safety glasses too, or you can read the owner's manual and pull the radio memory fuse for 10 minutes.
-JMFT
Sep 30, 2009 | OEM Systems Car Audio & Video
98 Accord V6 EX CD/Radio no sound despite correct code accepted
check the wirings of your speakers and then check the settings on your radio.
Jun 09, 2009 | 1993 Honda Accord
Battery ran down.now radio/clock don't work. flashes Error.can this be reset?
try taking the radio out and looking on the top for the parts number. call Honda and tell them what is going on and they will give you a 4 digit code that will reset the radio. i had the same problem with my 05 civic, did that and it worked for me.
good luck
May 29, 2009 | 2007 Honda Accord Sedan
Hooked my punch Punch P450.4 up to speakers and ran rca cables to front and it wont work
Hi Jon,  you need to hook the Remote wire up to the Radios  Blue remote wire.  The car battery power stays on all the time.  The blue Remote wire watches to see when the radio turns on, and signal the amp to turn on as well.
Dec 12, 2006 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Humming and static and not working
Angela You need to keep the system rewiried or at least checked out by a professional. It sound to me like the amplifier in the back of the car is staying on this would explain the battery problems and the hum. Sometimes when wiring in systems the amplifier will use the factory speakers in the car and will amplify the sound and you create a feedback loop. ( like putting a microphone in front of a speaker) If the amplifier is not on and the power cables are unhooked and you are getting this hum through just the radio. I would suspect a faulty radio. But I am guessing from what you described you have a miss wired stereo system.
Sep 09, 2006 | Sony CDX-F7005X CD Player
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
