Question about Newton Power MoGo (MG-100-01-0012-01) Mouse
Inability To Activate MOGO
I have followed the instructions - charged the Mouse; told the Windows XP to ignore the lack of a driver; pressed the connect button; inserted the Bluetooth USB dongal that came with the mouse and no pairing takes place even after ten minutes. I must be missing something.
Pairing is a two part process. The device to be paired has to be put in pairing mode and the host computer has to run the "search for new devices" wizaed in the Bluetooth Manager.
Once the computer identifies the device to be paired it has to be selected for connection.
Tha t will complete the link and it does not have to be repeated.
Posted on Dec 09, 2009
I solved the problem by upgrading the Bluesoleil software I was supplied with (Bluetooth) to the most recent version (at the modest cost of 19 Euros). After I did that, the proper menus came up to search for the mouse device and a connection was established! Of course, the user manual was no help.
Posted on Feb 03, 2009
My mouse scroller is not working
The above symptom is associated with, but not limited to, the following systems:
  • ThinkCentre M70e, M70z, M71e, M76, M77, M80, M81, M90, M90p, M90z, M91, M91p, Edge 71z, Edge 91z
Applies to:
  • Microsoft Windows 7 in XP Mode
The system is configured with the following:
Windows XP Mode in Windows Virtual PC on a computer that is running Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Lenovo USB mouse driver for Windows 7 (Lenovo Mouse Suite)
Additional Information:
As of writing this tip, Lenovo Mouse Suite Version 6.48 can be downloaded.
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS014888
Lenovo USB mouse driver for Windows 7 (32-bit and 64-bit), Vista (32-bit and 64-bit), and XP.Uninstall Lenovo Mouse Suite.
  1. Click Start, then click Control Panel, View By: Category.
  2. Under Programs, click Uninstall a program.
  3. Right-click Lenovo Mouse Suite, then click Uninstall/Change. You may see a dialog stating, "Windows needs your permission to continue." If you see this dialog, click Continue.
  4. Follow the instruction on the screen to complete the uninstall process.
Other steps.
If you still need some Lenovo Mouse Suite function under Windows 7, the following steps may effective.
  1. Mouse Properties
  2. Select "Lenovo" Tab > Advanced Properties.
  3. Select "Wheel" Tab
  4. Change Wheel setting to "Use Microsoft Office 97 Scrolling Emulation Only" from "Enable Universal Scrolling."
Feb 26, 2013 | Lenovo Computers & Internet
Tip
How to Enable Touchpad in a Laptop
TouchPad is disabled sometimes for no apparent reasons.To reactivate, first you restart your computer. If no change, you can activate it by going to the mouse properties. In some laptops, you can try pressing FN+F7.
If you are using Windows XP in your computer, you can do the following:
1. Go to control panel>mouse>device settings
2. Click enable
3. Click Apply
4. Click OK
NOTE: If the troubleshooting above does not work. Click on reset devices>Apply>OK. Then restart the computer.
*****If your computer runs in Windows 7/VISTA, then follow the following steps.
1. Go to control panel>hardware and devices>Devices and Printers>Mouse
2. CLick on the last setting on the right.
3. Make sure that the mouse in the list is enabled.
4. If disabled Click Enable device.
5. Click OK.
If the above troubleshooting does not make any changes. Update the driver of your touchpad. You can visit http://www.synaptics.com/ to get the drivers and software needed for your touchpad to work. Or, you can go to the website of your computer's manufacturer because they have the available updates and drivers which you can download and it will surely fix the problem.
Carloadrian
on Feb 03, 2011 | Computers & Internet
HP MoGo Presenter mouse - bad battery OOTB
Sometimes the x54 slot turns off to save power. You will have to go into settings to make sure this is set to stay on. This may also be an issue with your computer itself going into sleep modes to save power. I had a similar issue, and yes, the charging light was on but it wasn't enough to juice up the mouse. If you are sure this is set and it still doesn't work, return the mouse. I am not sure of a way to replace the battery without cracking the case open. It's got some glue on it.
Oct 16, 2012 | HP Mogo X54 Bluetooth Multimedia Mouse
How to install operating system
If you do not have the restore disks or a restore partition, you need to take this PC to a IT Professional to have it loaded for you. This will entail the Operating System, Updates, Drivers, and 3rd party antivirus and anti-spyware.
Aug 26, 2011 | Toshiba Satellite P105-S6197 Laptop
I have a wireless hp mouse and i cant connect to the piece you put into usb port. i push the connect button and a red light comes on to signal its searching for the piece, but it wont connect and Ive tried...
NO PC stated, (wow1)
NO OS stated (XP , VISTA , what?) Never post lacking this KEY FACTS. or you force the helper to GUESS.! (wrong)
wireless has many problems in this domain. (wireless most)(BLUTOOTH ORE OTHER WISE)
as do matching drivers to the mouse on unstated PC.
why post lacking what you own there, in total>?
EG: PC HP DV7-1234US, RUNNING XP 32BIT, SP3 LOADED
INTERNET WORKS ! NOW. OR WHAT?
this mouse has HP support on XP./VISTA and windows. 32 or 64bit
that is in fact 6 drivers total and NO MORE.
so go there get them (1 of 6) and load it?
get it while not delete, as it surely will be SOON.
https://support.hp.com/us-en/drivers/selfservice/hp-wireless-eco-comfort-mobile-mouse/3840767/model/3840433
the mouse can be bad. too. (clean it? yet)
or the USB port dead.
so try all usb ports see if the driver loads.
try mouse on other PC. W7 bet the best PC to get it working
as W7 has full support end to end, not older OS of any kind.
if using XP or VISTA the Microsoft servers are shut down now
for drivers, (not updates ,old) but they are killing online PnP support.
last month i tested this and 1/2 are gone, (roughly and MS told me so)
lets say you run W7
then make sure you are internet connected, or PnP will be DEAD
and the poor thing cant load unknown drivers lacking an internet connection (unless i teach you how to force load them and will not now)
If the mouse fails on W7 machine, with usb ports working
the MOUSE is END OF LIFE.
buy a new one for $5 off fleabay,? splurge?
IF RUNNING XP (WHY) MAKE SURE SERVICE PACK 3 IS LOADED
OR ITS ALL JUST BAD TO THE BONE, END TO END.
Sep 30, 2017 | HP Wireless Optical Mouse
I lost my cd installer where can i find a4tech
Follow this link to A4Tech website and follow these instructions:
1 ) Press Download button to download the driver - work for Win98, Windows 2000/XP/Vista/Win 7.
2 ) Save it somewhere where you will remember after download. We recommend that you save it on your desktop , so it will be easy to find .
3 ) After successfully downloading the driver , do not open the driver file until you make sure the following has completed : ***REMOVE / UNINSTALL any original mouse driver from the PC . ( If you forgot to do this part , your driver may not be able to install correctly and successfully later )
4 ) After the original mouse driver has been removed , open the downloaded file .
5 ) Follow the on-screen instructions .
6 ) When it's successfully installed , please restart your computer .
7 ) After you have restarted the computer , plug the webcam into your computer and it will automatically recognize the new hardware.
Dec 06, 2010 | A4tech PK-635 Webcam
Updated drivers, mouse no longer works, windows xp
Please try to use keyboard to uninstall Driver Robot. Please press the winkey (key with Windows Sign on it), and goto Control Panel with arrow keys and press enter. Now using arrow keys goto Add Remove Programs and press enter. Now navigate to driver robot and use TAB key to select the remove or uninstall button. Please follow the on screen instructions.
I hope this will resolve your problem. Please do rate my solution.
Regards, Rashid
Oct 28, 2009 | Compaq Presario S6000CL (DT072A) PC...
My computer is installed with XP Professional and my new Microsoft Mobile Mouse 3000 will not work. Why?
Make sure the batteries are new or charged.
To activate the mouse press the connect button on the receiver and look underneath the mouse for the connect button and press that.
All you have to do then is right click on the mouse to activate it.
Regards.
Sep 30, 2009 | Microsoft Wireless Mobile Mouse 3000
The mouse screws-up in normal mode after a little while - the pointer stops moving but items will high lite when you move the mouse. The mouse doesn't have any problems in safe mode. Problem started after...
The mouse is not the problem. The problem is with your mouse driver. It might be damaged. Try deleting the mouse driver and reinstalling it. Assuming you have Windows XP. Go to Start>Settings>Control Panel>System>Hardware>Device Manager>Mice and other pointing devices.
Delete all pointing devices, close everything, restart the computer and the system will detect the mouse, follow on screen instructions and install a new mouse driver. That will fix the problem.
Aug 25, 2009 | Microsoft Windows XP Home Edition English...
Canon Multipass c20 driver for XP
MULTIPASS C20/C50 ON WINDOWS 2000/XP This device is not compatible with Windows 2000 and Windows XP as a multifunctional device. For this product, Canon advertises compatibility with the following operating systems: Windows 95, 98, Millennium Edition (Windows ME).
Printing functionality may be possible by following the steps below.
Step 1 – Install a compatible printer driver.
1. Start the ‘Add Printer Wizard’ from the Printers folder (Windows 2000) or the Printers and Faxes folder (Windows XP).
2. Ensure that the ‘Automatically detect my plug and play printer’ tick-box is not ticked. Press next.
3. When prompted, ensure the printer port is selected on to LPT1. Press Next
4. When the list of manufacturers and models is displayed, click on Canon, and then BJC4200. Press next until the installation is completed.
5. The printer driver should now be installed.
If you are using the BC22e photo cartridge, you will need to download the BJC4200 driver from the www.canon.com.au website.
Step 2 – Setting the Multipass machine to Printer Mode.
1. On the Multipass keypad, press Function, followed by 0.
2. Press the left arrow key until you see Dos Printing.
3. Press Start twice.
If you have successfully completed the above instructions, you may now find that you are able to print to the Multipass machine. To restore the Multipass back to its original mode, press Function, and then Printer Reset.
Feb 06, 2008 | Canon MultiPASS C20 InkJet Printer
Newton Power MoGo (MG-100-01-0012-01) Mouse Logo
468 people viewed this question
Top Newton Power Computers & Internet Experts
David Payne
David Payne
Are you a Newton Power Computer and Internet Expert? Answer questions, earn points and help others
