Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer stopped i was doing a load of wash and it suddenly stopped. The machine is full of water still. I have checked the fuse box and everything is fine. Do you have any idea's that I can try? Thanks
  • 3 Answers
Check the "lid check switch". Replace it if it is bad. Had the same problem and in my case it was the lid check switch.
Posted on Feb 08, 2009
GE model wwse5240G washer suddenly stopped working full of water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | GE WWSE5240G
I have a series 90 washer and it just stopped and is full of water. It will not power up. where should I start?
must be overload trip. drain water first. reduce load. restart. if doesn't work, check CB or fuse inside the machine
Mar 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer does not rinse & spindry after getting submerged in water.
everything needs to be checked from the timer control button to the motor, im guessing it agitated through the wash cycle but wont spin now right? your flood could have damaged any number of items... run through ( with the machine unpluged ) and test the components for continuity and/or resistance.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Everything works fine but it will not spin
Hi, you got water pump problem, some pump have a filter you can remove and clean, or some some small clothing could get into it. or you can open water pump and manually check for foreign object. you can empty machine, by lowering drain hose to floor level, you will need somthing to collect water, then check pump.
Aug 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Washing machine
it is possible the heater is at fault try this first / then check motor / after these there could be an exposed wire shorting on the chassis . always remove plug from mains when carring out checks . good luck
Apr 20, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore 80 series washer
You should still be able to drain the water by selecting a spin cycle and closing the lid, unless the lid switch isnt working
Dec 01, 2007 | Washing Machines
My washer won't stop draing as it fills
Does the washer makes a full cycle properly and only problem is water's constinously draining ? If this is the phenomena, verify that the pipe discharged to the drain hose (the pipe that water going out from the machine)is at washer height up to one foot higher. Goog luck !
May 25, 2006 | GE WBB4500EWW Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
