Question about Bravetti Quad Blade Food Processor
Not coming on
Never used how does it come on?
    President:
  • 3,433 Answers
Does it have a switch that doesn't work? Unplug it and use the blade tool to rotate the whole motor . Turn it several times. Not all are tested and sometimes the brushes aren't seeated. Rotate in direction of normal rotation. Several rimes. Good Luck _Ned_
Posted on Oct 30, 2009
Why wont my chopper blade come off in the unlocked position?
Help! My Cuisinart is Stuck! - Chowhound
www.chowhound.com/post/cuisinart-stuck-353459
Dec 21, 2006 - Read the Help! My Cuisinart is Stuck! discussion from the Chowhound food community. ... The lid seems stuck and won't come off. I've tried pressing down,... Make sure all the buttons are in the neutral position. Reply ... In case of clarification- Turn the lid back on before unlocking, then twist off. Reply.
How to remove a stuck Kitchenaid Food Processor Blade (blade in ...
https://answers.yahoo.com/question/index?qid...
Aug 25, 2009 - Now the blade in the smaller bowl (4 cup) does not come off the bowl.... UNless i take out the 4 cup bowl blade, it doesnt allow me to remove the bowl ... I've used the screwdriver method for years in my shop with nearly 100% ...
Jan 12, 2016 | Food Processors
When I use the blender, oil comes out of the motor
The seal on the shaft is leaking, the cost of paying someone to replacing it would be more than what the machine is worth, unless you can DIY.
May 03, 2015 | Moulinex Food Processors
Sunbeam Freeway Continuous Flow Food processor - Can't Remove Inner (Perspex ) bowl to clean - plastic top of central spindle won't come off !
that top part is supose to come right off. try a little very hot water to "melt" any tiny bit of food that may have gotten down in there and kind of glued the top on. pour the hot water right on the platic top of spindle then tap on it with wooden spoon to try and break it loose. repeat this at least 3 times and if it doesn't come loose, try using a few drops of rubbing alcohol to unglue the top. worst case try putting a washcloth over the platic top and get a better hold of it with a very careful application of a pair of plyers. take extra care not to squeeze the plyers to tight to avoid cracking the plastic.
May 04, 2011 | Sunbeam Food Processors
How to remove motor shaft sleeve from KitchenAid Food Processor?
I just did this. I used a screwdriver and some needle-nose pliers to wedge and separate the shaft from the base. Once you've separated it by about 1/2 inch, it will come off easily. I simply used a mallet to install the new one.
Mar 06, 2010 | KitchenAid KFP750 Food Processor
Blade is broken can i get new blade
On the website they are offering a package where you can get a new blade, but it comes with a bunch of other things. The website is: http://www.buythebullet.com/
and this is the package they offer:
Deluxe Upgrade Kit Upgrade your Magic Bullet! You can save even more time and trouble in the kitchen with the Magic Bullet Deluxe package, which includes 2 additional Tall Bullet Cups and 1 additional Short Bullet Cup, plus 3 more Stay-Fresh Re-sealable Lids.
Using the Magic Bullet in our own homes we've found these extra Bullet Cups and Lids come in very handy when the others are being used to store leftovers in the fridge. Plus, you also get 1 extra Cross Blade. And since this is the blade you'll use the most, it's nice to have an extra one around when the other is in the dishwasher. If you have a family at home, the Magic Bullet Deluxe is a must! Upgrade your Magic Bullet today for just one payment of $29.97 (plus $6.99 shipping and handling).
Nov 26, 2009 | As Seen On TV Magic Bullet Food Processor
Grating
Any of the disc blades require the use of the detachable stem. The official "Fine Grating Disc" (which doesn't normally come supplied with the food processor) is mainly for grating cheese, but the shredder disc that comes supplied with the food processor will do the job for you.
Here is a link to the manual:
http://www.cuisinart.com/share/man/57_man.pdf
-Tha Mp3 Doctor
Apr 25, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Blender bottom stuck
I tried the vinegar thing but it didn't quite work. We blended some smoothies with yogurt and it leaked through the bottom. No big deal, we tightened it up. We didn't clean it immediately. By the time we went to clean it, it was stuck. The vinegar didn't work, tried baking soda with vinegar, didn't work. Finally we ran the bottom underneath hot water for about 5-10 minutes. Finally after one strong turn the bottom came off. We have an oyster, the base can be used as well to take the bottom off but it turns counter-clockwise.
Feb 26, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Power but not working.
Keep trying....one of the two parts either the bowl to the base, or the cover to the bowl is not locking....
Mar 08, 2008 | Kenmore KFP-70 Food Processor
Won't come on at all
If you do not have the main dish hooked up correctly it won't come on. I don't know the correct terminology, but there is a lip on the clear cup that slides into the control panel on the left side. It must be a safety major, because if that is not in place it will not work. Hope this helps. Don't throw it away. Deanna
May 21, 2007 | Hamilton Beach 702R Food Processor
Won't come on
I have been having the same problem. I know on the chopper, it has to be locked in real tight or it won't go on, but right now, I am on line searching as I wanted to use the blender, and I can't get mine on. Kathy Kirk
May 01, 2007 | Bravetti Platinum Pro Quad-Blade Food...
Bravetti Quad Blade Food Processor Logo
44 people viewed this question
Top Bravetti Food Processors Experts
Greg Cann
Greg Cann
Lawrence Oravetz
Are you a Bravetti Food Processor Expert? Answer questions, earn points and help others
