Question about Sharp AR-M355N Copier
How to fax?
Can someone please tell me how to use the fax feature on the Sharp AR-M355N copier/MFP?
You access the fax functions (if optional kit is installed) by way of the Image Send button on your panel. Press Image Send, then press the FAX key on the screen. dial as you would any fax when the number is dialed and the document is in the feeder, press the start (copy) button and you are faxing...
Les Olson Company, Sharps #1 ind. Dealer in the USA. Selling Sharp in Utah and Las Vegas with 7 locations to serve you.
Posted on Feb 09, 2009
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
How do I set up an address to the frequently used addresses tabs on sharp ar m355n?
on the web page(accessed by typing the machines' IP address into a web browser)
click destination, the username is admin, and the password is Sharp
then put a check next to the person's name, and click edit
then check the "Frequently used" box on the page and click submit.
Skelton Business Equipment Houston Copiers
Jun 19, 2014 | Sharp AR-M355N Copier
Sharp copier USB connection not recognized
WHAT OS U USE?
TRY THIS LINKS......
http://www.solvusoft.com/en/update/drivers/copier/sharp/ar-m355n/sub-models/
http://iprinterdrivers.info/download-driver-for-sharp-ar-m355n-printer.html
http://www.sharp-world.com/products/copier/downloads/index.html
AND ALWAYS U CAN GO FROM -CONTROL PANEL- TO -DEVISE MANAGER- AND FROM THERE U SEE THE PRINTER DOUBLE CLIK ON IT AND U SEE INFO OF DEVISE(PRINTER) LIKE DEV ID (DEVISE ID) COPY THE ID AND GO THERE
https://devid.info/ AND JUST PASTE AND FOUND THE DRIVERS
Oct 13, 2017 | Sharp Ar-m355n Copier Printer Scanner Fax...
I have a sharp AR-M355N machine and I keep getting error code F2-00, what does this mean, is there a specific fix for it
This code is Toner Control Sensor open/trouble.
Check connection of the toner control sensor.
Check connection of connector and harness to the main PWB.
Check for disconnection of harness.
If all is fine, replace the sensor.
Nov 09, 2010 | Sharp AR-M355N Copier
I have a AR M355N and it gives me "finisher out of service." Do I need all the trays installed to clear this?
Maybe? Most likely the problem could be with the stapler unit not finding HP. Did you have a error code before the finsher could not be used?
May 27, 2010 | Sharp AR-M355N Copier
Intermittent doc feed on ar-m355n, sometime overlaps pages? service note or bulliten on a modification or?
If you have not replaced the Adf paper pick up & paper feed roller & the seperation sheet, I would do that, also have you ruffed up the shaft with the one way ball bearing on it? Try that and have you cleaned the paper feed clutch's.. Good Luck...
May 27, 2009 | Sharp AR-M355N Copier
Backing up toner in process unit and keeping noise in process
The sound you are hearing is probably the hopper gear skipping. It generally indicates blockage. Check the entire path of the toner and check for caked toner. It will be messy but usually if you get the hard toner out your good to go unless a drive gear has been stripped further in.
Apr 21, 2009 | Sharp AR-M355N Copier
Sharp AR-M355N Copier Logo
219 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
