Question about Insignia 19 in. Widescreen Flat-Panel LCD HDTV/DVD Combo
Can an LCD tv be kept in the garage without damage?
I plan to get an LCD tv that would be housed in the garage for my husband to watch while he is working outside. Will the temperature changes, hot or cold, affect the tv? Is it feasible to keep the tv in the garage without damaging it?
    President:
  • 1,077 Answers
Well, It depends on the conditions of where you live.
Too much dust and moisture will cause a lot of problems.
Getting too cold will cause moisture to condense.
Getting too hot will cause parts inside not to cool off properly.
The TV should be ok as long as you keep it in a cool, dry place.
Posted on Feb 04, 2009
Rebel xsi review time doesn't show
Let the camera in the zip bag reach the same cold temperature outside before you take a picture. You may need to warm the battery in your hands/pocket for the battery to operating temperature.
After you have taken your photos, place the camera back in the zip bag so when you return inside a warm house you won't get condensation on the camera/lens. You need to let the camera reach room temperature before you take photos inside the house.
Jan 30, 2013 | Canon Digital Rebel XSi Digital Camera
Tip
Wheelchair Accessible vehicle for Disabled
Last month me, my husband and our 2 children make a plan for the picnic .My husband is permanent in wheelchair and he is not able to go outside because of his spinal cord injury. So i make a plan for picnic and we go by our van which is fully wheelchair accessible. We enjoy alot their and my husband diid not get due to our wheelchair vehicle. http://www.csv.com.au/wheelchair-ramps
on Mar 31, 2015 | Health & Beauty
My 95 chevey tahoe is blowing hot air and the heater is not even on,what could be causing this?
Most likely, you have a defective temperature actuator. (See diagram below) You can see/get to the actuator by removing the glove box assembly. Turn the ignition on and change the temperature control from hot to cold and/or cold to hot. Watch the white ring on the actuator (See picture) and see if it turns. If it does not turn, replacing the actuator is very likely to fix your problem. (There are other things that can cause this to not work, but most of the time, it is the actuator itself)
If the actuator is working and the temperature coming out the vents does not change, then the blend air door is broken. (This is the part that the actuator moves.) This is also fairly common and requires removal of the entire HVAC housing assembly to repair.
May 12, 2012 | 1995 Chevrolet Tahoe
Hello, I recently had a Rinnai tankless water heater installed. The old water heater was in the garage. The new tankless heater is installed outside, and is about 25 feet away from where the old one...
I agree with you. The foam insulation should only be on the Hot Water side. The cold water side doesn't make any difference, as that temperature rarely changes in California.
Hope this helped you AK, thanks for choosing FixYa.
Aug 10, 2011 | Heating & Cooling
My boiler is in an outside cupboard and a frostat was fitted.My heating comes on at night and in the day when it is cold and I don't want it to as it is costing me alot of money in extra gas usage, plus it...
I am not a expert by any means but have a similar problem with an outside boiler, but mine is in a garage. It strikes me that if yours is located in a more confined space you could place a small parafin heater in the cupboard which would raise the temperature sufficiently to stop the frostat activating the boiler and also be sufficient to protect the pipes from frost. Hope this helps. John.
Nov 30, 2010 | Honeywell Heating & Cooling
Can a freezer be operated in temperatures below freezing.
Yes,It will work just as it should.
Please rate this a fixya
May 18, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Heater won't work below 0 degrees farenheit
Unfortunately this was a firmware bug in the early models. The "CC" is simply indicating that the temperature reading is under 0 degrees. The actual problem is that the thermistor curve is implemented in firmware via a lookup table. Temperatures below -10 fall out of the table and the firmware incorrectly interprets this as being a hot temperature.
The only fix is to replace the control.
Jan 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Bush freeview digital tft lcd tv 37inch sound no picture
how can i change the sound from 6.0 to 5.5 the tv is bush but the philips remot can oparet it is it rong
Sep 09, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Insignia 19 in. Widescreen Flat-Panel LCD HDTV/DVD Combo Logo
4,321 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
