Question about LG 37LG30 37 in. LCD HDTV
Volume trouble with 37LG30
I have trouble getting enough volume with on my 37LG30. On many channels, I have to have the volume up to 90%, and occasionally, I have to turn the volume all the way up. I have had several people comment on this since I got the TV, so it is not just me. Also, there is a setting that is supposed to even out the sound levels between programming and commercials, but this option does not seem to work. (I get my programming via Dish Network.)
  • skyhawk77 Feb 09, 2009
    I have the same problem with my 37LG30. If I find a solution, I will Post it
  • dom3094 May 19, 2009
    The volume needs to be turned almost completely up in order to hear normal programming on my TWC HD cable box.  However, when I play DVD's on the PS3 it sounds great.  I've tried adjusting everything I can think of in the settings on both the cable box and the TV and I've had no luck.
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the Motorola box, not necessarily whichever box Dish Network supplies, but there may be a similar setup option available in your Dish box.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 20, 2009
    New Friend:
    Problem Solver:
  • 5 Answers
Well if you want to get rid of he tv i offer to buy it from you
Habunoki@yahoo.com
Posted on Feb 24, 2009
Sony walkman volume
spray 90% rubbing alcohol from a spray bottle into the volume button area push the button reapeatedly or, turn the knob back and forth then: let it dry for about an hour then try to use it the control should be clean and working again.
Dec 03, 2013 | Audio Players & Recorders
Remote does not work
Did you drop the remote lately my dog loves the plastic and knarls and slobers on them. Go buy a cheap replacement and try it
Mar 24, 2010 | LG 37LG30 37 in. LCD HDTV
LG LCD TV volume/sensor problems
it could be 2 issues: faulty remotes or stuck buttons on tv's keyboard. Where did you get 2 remotes? cable or directtv boxes? those are universal and must be programed to work with tvs. or, do you have 2 identical LG remotes in your household? either way, if you have kids on premises and lot of drinks carried around, remotes could be contaminated with fluids inside and malfunctioned. You must become a CSI and figure it out!
Good luck and let me know the results.
Alex's tv.
Feb 22, 2010 | LG 37LG30 37 in. LCD HDTV
Right channel low volume on Sony STR-685
Here you go buddy:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C225335&fes=true&mdl=STRDE685
Sep 20, 2009 | Sony STR-DE685 Receiver
Difficulty hearing Samsung LCD tv even with volume up to 100%
Some models are just that way. I would invest in a small surround sound system for them.
Jun 18, 2009 | LG 37LG30 37 in. LCD HDTV
Low volume on LG HDTV
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
My sky remote only works part of tv
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
Right you said in your post that it only works part of the tv, what this is when you have saved the code into the remote it is very close but not the correct code for the LG Model you have. So imput the code as mentioned above but when your checking the volume dont press SELECT straight away try the help button. power button etc then save that code if it works them. when it is the correct code you should be able to press the TV button then power = power . Help = changes av / source. Number button change channels etc. On certain tv's on a sky + or hd the pause/play changes the aspect ration on the tv aswell. When this sorts you out please leave a thumbs up cheers
Little Dish Fitter
Mar 20, 2009 | LG 37LG30 37 in. LCD HDTV
Auto volume has little or no effect on loud commercials
This may not be a problem. I believe there is an audio effect used by video production houses to 'boost' the presence of an ads audio and this effect is not picked up by the electronic device's (in this case TV) volume stabilizing software. It is intentional by the makers of the ads.
A work-around could be to try different configurations on your TV's audio settings, such as just mono, or just 2channel stereo, or surround sound - on or off, increasing/decreasing bass and treble levels in different combinations.
The down-side to this is to get a comfortable, uniform level of volume across the board, you maybe sacrificing some sound quality - but, as with our eyes, our ears adjust well quickly (hence don't listen to too loud sounds) and what you may not like now, will sound ok tomorrow.
I can't tell if there is a fault or not, but this may help if you "trial" some options.
Jan 29, 2009 | LG 37LG30 37 in. LCD HDTV
Auto volume control
Hello, Sorry this isn't really a solution but when I went into Future Shop to inquire about purchasing a large Plasma TV with this "auto volume" feature I was told that this is not what it does. I thought what you did, that it controlled the annoyingly loud commercials. I was informed that it regulates volume between stations. So when you change channels, the volume stays consistant. I don't know why this is considered a feature when it's not really a problem. Please tell me if I was misinformed, but this would explain why the feature is not quietening the commercials.
Jan 19, 2009 | LG 37LG30 37 in. LCD HDTV
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
LG 37LG30 37 in. LCD HDTV Logo
677 people viewed this question
Computer Repairing
Computer Repairing
