Question about BenQ PDP-46W1 46 in. HD-Ready Plasma Television
Bad lg plama
My 50 inch lg plasma has a vertical green line down right down the middle one month old
    President:
  • 1,077 Answers
Warranty, Warranty, Warranty. Those new screens cost an arm and a leg. Don't let them give you "NO" for an answer.
Posted on Feb 04, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
It is going to be one of two basic issues:
1. There is a poor connection somewhere in the set--either with a plug or cable or on one of the boards.
2. There is a board that is beginning to fail causing this.
Either would require a shop and may or may not be worth the cause.
Having seen hundreds of these sets all are more prone to flaky problems than the older sets and average life span is 3-5 years.
Shop I work for 80% of them are 2 years old or less.
If problem began shortly after set was moved or relocated I would lean towards a bad connection somewhere.
Mar 17, 2012 | LG 50PK550 50 HDTV Plasma TV
LG32 7000 14 mths old Thin vertical green line some 8 inches long runnig up from the bottom of screen just off midline
Unfortunately this is a problem with the screen & the only remedy is to have the screen replaced. I know you say it is only 14 months old so check if you still have an extended warranty from the place you bought it from.
Feb 04, 2011 | LG 50PX5D 50 in. Plasma HDTV
A one inch black line down middle of tv on my lg 42 plasma and some times two lines
The LG plasma TV with the black vertical bands, may be the bad connections, you can try to reconnect the cables on the X board. If the bad connections on the panel side, you need to replace the panel.
May 08, 2010 | LG Televison & Video
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
BenQ PDP-46W1 46 in. HD-Ready Plasma Television Logo
262 people viewed this question
Top BenQ Televison & Video Experts
Electro Med Services...
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
