Question about Toshiba Office Equipment & Supplies
Diagonal 1/2 inch invisible lines on paper
The toner looked like it needed to be changed, so we changed it....then the lines appeared. is it a toner issue...
i wiped the glass and still it didn't help.
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; There are two factors cause this problem,
1, charge and discharge corona wire need to clean.
2, need to replace developer.
Posted on Feb 03, 2009
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
My copies have a thin blank streak about 1 inch in on the left side. the streak is about 1/4 inch wide and goes down the whole sheet of paper
Start a print or copy, and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Clean the loose toner up with a dry lint free cloth.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Brother DCP 1000 All-In-One Laser Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
I have three horizontal lines across the printed document
Here is the print defect information from the service manual.
1. Toner Cartridge.
The circumference of the photoconductive drum is 3.75 inches (94mm). The circumference of the developer roller is 2 inches (51mm). If a defect appears in the print image at these intervals, assume the defect is associated with the Toner Cartridge. Replace the Toner Cartridge.
2. Fuser Assembly.
The Fuser Roller’s circumference is approximately 2.5 inches (63mm) for the LJ4, and 3-1/8 (79mm) for the LJ4+/5. If a defect
appears at this interval, assume the defect is associated with the Fuser Assembly. Clean the Fuser Assembly rollers. Replace the assembly if necessary.
3. Dirty Roller.
Any dirty roller along the paper path may result in a pattern of
repetitive print image defects. Examine and clean rollers along the
paper path.
We have the full service manual download available for $6.95 if you need it. We also carry all repair parts for your printer.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jun 29, 2009 | HP LaserJet 4 plus Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Dark Horizontal Lines on Faxes
on the drum unit that you put your toner inn, There is a blue or green slide lever move the slide back and fourth 10-15 times. If you have some van air blow that area out ( F.Y.I. if you do this some toner will fly out ) if this does not take care of it the drum unit my be bad,
do a 1/2 print test. copier something with a lot of print. open front cover when the paper is 1/2 way through the machine remove drum. Look art the paper and the green drum if the marks are on the paper & drum then the drum is bad. If not the fuser asm is bad, the part that gits hot when melting the toner on the paper,
Jan 29, 2009 | Brother IntelliFax-2820 Laser Fax
Regular toner drag marks on printout
MACHINE DRUM UNIT, IMAGE BELT, AND TONER UNIT NEED TO BE REMOVED AND CHECKED AND CLEANED IF THEY LOOK GOOD THERE MIGHT BE A PIECE OF PAPER BLOCKING THE LASER SITE AREA INSIDE THE MACHINE IF ALL IS GOOD, CHECK THE FUSER FOR WOREN HOT ROLLER ,DIRT OR PAPER WILL BLOCK THE IMAGE TH THE PAPER
Dec 30, 2007 | Konica Minolta magicolor 2400 Laser...
49 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
