Can not access web interface ''controller'' - Aprilaire 8825
The device has a web interface to allow you to change the IP address, etc. It recently stopped allowing the computer access to the web configurator. We reset the IP to the default address of 192.168.0.200 and I can ping it across the network as well as with a cross over cable going directly into the box. However; even though I can ping the device, the web ''configurator'' will not open. I have the correct version of Java installed.
(Aprilaire 8825 System Controller)
  • Anonymous Apr 26, 2009
    I have exactly the same problem
There is a problem w/ newer versions JAVA communicating w/ the controller, and aprilaire has no immediate plans to update their software. I work for a h/c contractor and we have been installing quite a few of these 8825 systems - starting to get quite a few calls w/ the same symptoms. AA said to roll back the java and use mozilla as the browser. Am in the process of getting an optimum environment - so let me know if anyone has any luck
Posted on Nov 09, 2010
    Problem Solver:
  • 15 Answers
Aprilaire has tech svc google search and call them they are out of mich.
Posted on Feb 04, 2009
D-Link DES-1008D 8-Port drivers
Drivers are not required, the device is a networking device and doesn't interact with the OS directly anyway.
What you might be looking for is the Web Interface that allows you to change settings, update firmware etc.
By default most are configured to either 19.168.0.1 / 10.0.0.1 / 10.1.1.1
Open your web browser, type one of those into the web address bar until you find the one that brings up the web page, from here you should be able to configure a few things.
If you are unsure click start > run > type: cmd > hit enter> a dos prompt appears, now type: tracert www.google.com
You will see IP addresses appear as the computer traces the path the packets are taking to reach google, what you are interested in is the first address that is in that list, that should be your switch ip address and all you have to do now, is type that address in your browser address bar. This should now bring up the configuration page for the switch.
Still unsure of the address, head to D-links website and find the support link and search for your model of switch, from here you can bring up the detailed users guide which will contain instructions on how to access the Web interface also.
Apr 15, 2013 | D-Link DES-1008D 8-Port Ethernet Switch...
Hallo, i recently installed and configured a WAp200E-EU-UK access point. i changed the default ip address to 192.168.1.11 and changed the SSID and key, when i logged out of the web interface, i could not...
As you have changed the default IP Address of the router, you can access the router by using the newly assigned IP (192.168.1.11) and new username and password (if you have made any changes to the defaults).
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 20, 2011 | Linksys (WAP200) (WAP200-UK) 802.11b/g...
Need to allow a telnet session thru a speedstream 5660 modem/router having a public ip and allow it to connect to a private ip on the internal LAN. how do i accomplish this?
According to the user manual:
Page 16:
HTTP Web-browser Access
Most HTML browsers can be used, though Internet Explorer 4.0 or Netscape 4.0 are recommended. IE 2.0 and Netscape 2.0 and their predecessors are not supported. The HTML interface can be used to access the LAN (or WAN) IP address or it can be used with FTP to upload and download files to and from the router.
To log on to the modem via HTML:
1 Bring up your favorite web browser.
2 Enter the Ethernet IP address of the router (10.0.0.1 or Speedstream) in the "Location" or "Address" area where you enter web page addresses.
3 Refer to "HTML Web Interface" on page 20.
Page 20:
HTML Web Interface
The HTML interface for the router first displays a page showing the current configuration of the router. The first page also provides links to the following functions:
Advanced Setup
Leads to a more detailed interface with several links that allow more in-depth configuration of functions available on the router. This interface provides the following links:
Configuration Procedures
Status and Statistics
Command List
This is where the user manual ends. I would suggest clicking "Configuration Procedures" and find the section for configuring Network Address Translation (NAT).
In that section (if it exists), you'll want to provide the private IP address of the computer running the Telnet server and forward port 23 to this IP address.
If NAT capabilities do not exist, I would consider changing the router to Gateway mode (described in the user manual) and buying your own router to handle the NAT firewall.
Dec 29, 2010 | Efficient Networks SpeedStream 5660 Router
How do i add the mac address of my printer to the list of permitted devices
Disconnect the Ethernet cable between the router and the cable-modem (or DSL-modem).
Access the web-interface inside the router.
Allow "all" MAC-addresses to access the router.
Turn the printer off.
Turn the printer on, so that it gets a "fresh" IP-address from the router.
On the router's web-interface, get it to show a list of the "active" DHCP-connections.
It should show the IP-address and MAC-address for your printer.
Copy that MAC-address, and the MAC-address of your computer.
On the router's web-interface, access the table of "allowable" MAC-addresses.
Add the two MAC-addresses.
Enable the "selected MAC-addresses only" option.
Reconnect the Ethernet cable.
Nov 04, 2010 | Computers & Internet
I want to change the default SSID name
log on the router using the default gateway IP address and change it. if you need more details post router model/make and we'll assist
Feb 02, 2010 | Computers & Internet
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Cannot telnet to SN0108 altusen serial over net
Please change the ip address to 192.168.1.32 or something and try telnet.  Thanks ,
Vipin
Mar 16, 2009 | Altusen 8PORT POWER ON THE NET W/ (PN0108)
I need to change the IP address on my hp color laser jet 2840 coud you help me with that
Most HP printers can be reset to factory defaults (or cold-reset ) by turning the printer off and holding down the Online or Go button while turning the printer back on. The printer control panel display should read "Cold Reset" or "Restoring Factory Settings" or something like these lines. This will remove any IP address that the printer had previously.
When you plug it in, your router should have assigned an ip address automatically. Go into your router and look at the attached devices and it will show you what ip address has been assigned to each device on your network.
Use Web Interface or Manually Assign an IP address NOTE: Network HP Printers allow you to manage them via Internet Explorer. You can enter the IP address that the printer currently has and access its configuration settings. This assumes that the web interface hasn't been locked.
NOTE: We recommend that you install the latest version of Sun's Java software before trying these steps. See this How To: How to Update Sun's Java 2 Runtime Environment Plug-in.
  1. Print the Configuration page if needed. You will be entering the "current" IP Address.
  2. Open Internet Explorer. Delete EVERYTHING from the Address line.
  3. Enter the IP Address in the Address line and press Enter.
  4. You should then connect to the printer. If this fail, go to the next section to assign the IP address manually.
    NOTE: There are 2 basics versions of the web interface. Type 1 is on newer printers. Type 2 is on older models
  5. Type 1: Click the Networking tab.
    Type 2: Click the Administration button. Click the Configuration tab.
  6. Edit the IP address, Subnet Mask, and Gateway as needed.
  7. Do not change any other fields.
  8. Scroll to the bottom and click Apply. Click OK.
  9. Close Internet Explorer.
  10. Restart the Printer. Print the Configuration page to see if number was set.
NOTE: If the above steps do not allow you to assign the IP address via the Wizard, you will need to do it through at the printer itself.
  1. Go to this HP Support Page.
    Configuring TCP/IP through the Front Control Panel
  2. Click the link to your printer model. Highlight these steps.
  3. From the File menu choose Print. In the Page Range section, click Selection. Click Print.
    Note: For the complete printer user guide, go to the HP Printers Support & Troubleshooting page. Locate your specific printer type and model. On its home page, under self-help resources, click the manuals link. Download the printer's User Guide (not the Getting Started Guide). Look for steps to manually configure TCP/IP parameters from the printer control panel.
  4. Follow the steps from the printout to assign the desired IP Address to the printer.
    IP address will be entered at the IP BYTE prompt
    Subnet mask is entered at SM BYTE prompt
    Gateway address is entered at GW BYTE prompt
    Note: The syslog server IP address (LG BYTE 1=) and timeout (TIMEOUT=) do not need configured.
  5. Once the IP Address is entered, restart the Printer. Print the Configuration page to see if number was set.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | HP LaserJet 2840 Printer
Configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Heating & Cooling Logo
410 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
