Question about Compal DL71-TVT Notebook
Housing for dl71 cracked and hinges broken.
I need to get a replacemnet housing for my dl 71 notebook.i dropped it and it cracked and damaged the corner hinges and now very difficult to open and close as the hinge is not secured.
Acer Aspire E1-571-6650 would not charge. Problem thought to be DC Jack (AC Adapter would not fix and DC Jack seemed loose). Had the same problem a year ago in July and it was fixed. Original charger...
Difficult to comment but if a laptop comes in for me to repair and the hinge is broken and maybe cabinet damage, I would offer to replace the broken parts and replace the DC jack, if it was faulty. It is part of the service but may not be cheap to repair!
Hinges usually become loose and very rarely break.
Did the laptop work on the power supply but not on battery?
Feb 24, 2014 | Acer Aspire Computers & Internet
I Need Modem Driver For My Compal DL71 And Ethernet Controller list for the drivers thre you go if this works please let me know / rate
Mar 16, 2011 | ASI COMPAL DL71 15.4 WXGA 915GM SONOMA...
Do u knw where I can get a mother board for the compal DL71?
Here's one option for all your computer part needs, hope this helps!
please leave rating/feedback if this is helpful, thanks!
Oct 17, 2010 | ASI COMPAL DL71 15.4 WXGA 915GM SONOMA...
Hinges cover crack , lcd ok... hinge brackets broken
ouch how did you manage that? all you can do is buy a new case (if they still sell them) or carefuly glue it back together trying not to open the screen.... as there is a ribbon cable in there which if damaged canruin your display completely!!! i would know i had a similar problem.. if you do damage it domt pannic they are very cheap and i would recromend ordering online as shops have a tendonsy to rip you off.
if you had cover for it it is useless now :-( as the crack shows that you have dropped it.
hope this helps.
Nov 22, 2009 | Compaq Presario 700 470024-192 Notebook
Cracking the case to get to the left hinge
If you don't know how, then take the computer to a qualified/certified technician, to avoid self-inflicted damage.
Wouldn't a drop of oil be all you need?
Sep 18, 2009 | Gateway M460A (2900728) PC Notebook
Body replacement...
The top one works well for me and its cheep but lacks portability.
a new body would likely cost more than its worth and have the same defects.
Sep 13, 2009 | ASI COMPAL DL71 15.4 WXGA 915GM SONOMA...
Broken hinge
Depending on the damage you can try to super glue it back.
Apart from that you will have to take it to a laptop repair shop and see what they say.
Jul 16, 2009 | Dell Inspiron 1525 Notebook
Cracked keyboard housing
u no need to worry u just make clear that u always use note book with care and if it dropped then it damaged from its base side also and the upperside is infected so it is very clear that it is not ur falt as u described.....
best of luck
Mar 04, 2009 | Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz...
Nintendo ds broken hinge
need to replace the hinge (shell housing) about $25.00
Aug 22, 2008 | Nintendo DS Lite Console
Broken hinge on laptop
These are usually sold as a whole from the manufacturer with the monitor attached. If the display is cracked, this is what you want anyway, but if not, you will have to call customer support and try to get just the plastic housing.
Or see if there is a third party who sells them in either stock configuration or graphics if you prefer.
Apr 02, 2008 | Computers & Internet
Computers & Internet Logo
146 people viewed this question
Top Compal Computers & Internet Experts
Phani Kiran...
Phani Kiran...
Are you a Compal Computer and Internet Expert? Answer questions, earn points and help others
