Question about Harman Kardon HK19.5 Computer Speakers
I need a power source for my HK19.5 computer speakers.
Can I purchase a new power source? The back of the speakers shows power source to be 15V, 1.5 Amp outlet cord. Is this something I can purchase at a computer store? Radio Shack did not have this odd size. If I purchased on this website can you quote a price?
Thank you for your time.
  • billheitman Feb 14, 2009
    Thanks my friend. The answer was in front of my nose the whole time. The solution did require me to purchase used speakers to get the source but it helped.
  • 685 Answers
You can order on ebay and they will give u the price on there this is only somewhere to help you fimd what your looking for or if you need help with fixing something
Posted on Feb 03, 2009
The power supplies / ac adapters for my AW-871 speakers were both lost in a recent move. The speakers show input of 15v center + but no power spec. Do you have a suggestion for replacements? Thanks for...
Higher voltage then required is not so recommended, internal circuit may over voltage driven. some power amp max limit may fall within 18V only. See this link If your speaker power less then 30w you can choose 15V 2A will do or else select higher spec.
Jul 23, 2011 | Acoustic Research 900MHz Wireless Stereo...
Cannot find power adapter for mms171w philips system. Needs AC/AC adapter with 10v ac at 1.8 amps output. Cannot find aftermarket counterpart either. Help. Lost adapter while moving.
What does the other end of the adapter look like?
Is it a conventional circular one or is it a special port like it's thin square like or USB like maybe?
If it's conventional any 10v 1.8amp or 2 amp output should do and a lot of them are available in e-bay or if there's a Best Buy, Staples, Etc near you can just drop a visit purchase one and it should work like a charm.
However if it's not a conventional adapter you may have to contact philips and purchase one that is compatible from them.
Hope this shed some light on your problem!
May 31, 2011 | Philips MMS171 Computer Speakers
I have no power supply cord for my labtec lcs-1030 speakers- what do i replace it with? i cannot find specs for it anywhere online
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
Mar 24, 2011 | Labtec LCS 1030 Computer Speakers
Need the AC 15V 1.1a power supply
Hi Tracy,
Wow, this was a hard one. I called both Harman Kardon and Dell, seems HK made the speakers for Dell, but neither company carries parts any more. I called Radio Shack thinking they would have a generic power supply, not even close. I looked at several places on the internet and had no luck.
I do have a little good news, I was able to find a few on Ebay, so if you don't mind buying used, you can get a power supply there. They even have a Buy Now offer so you would not have to bid on it. The power supplies are listed as 1100mA which is the same as 1.1A.
Also, if you get the it and the plug in is not the right size, take the speaker to Radio Shack and they will be able to sell you the correct plug, all you will have to do is splice in the new plug. With it having an AC output, you don't even have to worry about the wires being crossed as you would with DC. Hope this helps you.
Here are the links:
http://cgi.ebay.com/Harman-Kardon-A481511OT-15V-1100mA-Black-AC-Adapter_W0QQitemZ190450725250QQcategoryZ79846QQcmdZViewItem
http://compare.ebay.com/like/370463130288?ltyp=AllFixedPriceItemTypes&_dmd=Gallery&var=sbar&rvr_id=189044360544&crlp=1_263602_304692&UA=L*F%3F&GUID=0234523512d0a0b3f8f79f17ff3c9895&itemid=370463130288&ff4=263602_304692
http://cgi.ebay.com/Harman-Kardon-A481511OT-HK-01T-AC-Adapter-15V-1100mA_W0QQitemZ190450725272QQcategoryZ79846QQcmdZViewItem
Dec 23, 2010 | Harman Kardon HK19.5 Computer Speakers
I need a 15V AC to AC adapter for ouir Audio Source home theatre subwoofer. Can you help? I can easily find 15V AC to DC and the only 15V AC to AC power source cables I can find are for Toshiba...
Sure! An Audio Source Sub power adapter is $38 +$9 shipping from this seller. It's importnat to know the power requirements of the device in either watts or amps to choose an adapter capable of serving the load. Otherwise, it might be too small and cause a fire. This one looks like it is like the one supplied originally.
I hope this helped & good luck!!
Nov 01, 2010 | Audio Players & Recorders
I have polk audio speakers that came with my old hp f50. I just purchased a new hp but can't get my speakers to work
The old speakers are not compatible. Your new computer is looking for an external power source for the speakers, the older polk speakers that came with Hp computers have none.
Sep 15, 2010 | Polk Audio AMR50 Computer Speakers
I need a new power supply for Labtec LCS 1030 speakers and trying to obtain specs and power plug information. Anybody have the information available?
I know this is a little late, but the power supply that these speakers use appears to be 5mm across. The output specifications are 15V DC, 1000mAh (1A), with the center pin being negative.
Feb 17, 2010 | Labtec LCS 1030 Computer Speakers
Seems to be no power to speakers.
Disconnect green speaker jack from computer and see if you get a green power light on speakers. If the speakers indicate they have power, your sound card or circuit is shorting out the speakers. If you still have no power to the speakers when disconnected from computer, then no green light means no power to speakers. Either you’re A.C. adaptor is bad or the speakers are shorted out. You have 2 options:
1) Replace A.C. adaptor.
2) Replace speakers.
If you buy new speakers, make sure that they have their own power source (A.C. adaptor).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 19, 2009 | Dell A215 Computer Speakers
Monsoon power cord needed on old computer speakers
leejean
the very best way to solve your problem, go to the electronic store and ask a dc power supply adapter 15volt 2A,vice versa polarity. with universal connector for it sure you can select the right type connector do you have for it fit to the back socket of your unit. before you connect read the correct polarity of your device you see label at back (+, -). and set the polarity output of the adapter correspond to your unit,,,
johnfil,,,,
Oct 07, 2008 | Level 9 Sound Designs Monsoon Planar Media...
Transformer output
the volts are not as important as the amps the amps must be the same
Dec 01, 2007 | Harman Kardon HK19.5 Computer Speakers
Harman Kardon HK19.5 Computer Speakers Logo
250 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
