Question about Microsoft Windows Vista Ultimate Edition
When I am Boot
When I am start my pc I show this dilog box why-
" Windows -Registtry Recovery
One of the files Containing the System's Registry data had to be re covered by use of a log or alternate Copy. the recovery was successful.
please solve this problem
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Does it do this every single time you turn on your pc
  • 3 Answers
Hi
change your windows dvd and and boot windows again
Posted on Feb 03, 2009
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
Sep 19, 2011 | HP Pavilion dv9925nr Notebook
System error
I'd recommend that you use some data recovery program
Sep 06, 2011 | Computers & Internet
It will not boot up stops when it say detecting storage device
Remove the hard drive and put it into an enclosure. Plug it into another computer as a slave. Then you can copy your files on it.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it, you can recover data from hard drive with data recovery program. Asoftech data recovery is a professional data recovery program that can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage, system sabotage, virus attack etc.
Sep 03, 2011 | Acer Aspireā„¢ T180 PC Desktop
I have a DELL E4300 laptop. It would not start up due to 2000-0146 error. Any suggestion to recover the data knowing that I may have to replace with a new hard dirve.
Most of the boot up of problem because ofhardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allowsusers to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (notfrom PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file.Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer andpress "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority andpress Enter. Please choose 1st Boot Device to USB, and then press F10 to savesetting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fixit.If not,reinstall it.If you have no backups for all your data,you can useTenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How toRecover Data from Computer Won't Boot Up?Windows Data Recovery.
Aug 31, 2011 | Dell Latitude E4300 PC Notebook
When i open my laptop, then boot, it goes to this windows 98 startup menu which has following options: reboot to windows xp, recover windows xp w/ full hd, recover xp w/ 2 partitions, and recover xp w/ 1...
first, recover your files. You will need to use something like this data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Apr 03, 2011 | ASUS W7J Notebook
Trying to full system recovery, but showing error 15
  • error 15 = Exception was not allocated.
  • The registry is corrupted. The structure of one of the files containing registry data is corrupted, or the system's memory image of the file is corrupted, or the file could not be recovered because the alternate copy or log was absent or corrupted.
Aug 25, 2010 | HP Mini 1000 Netbook
System is blue screening giving an error meaasge ....registry file corrupt. error 0000146. I am told there may be a hardrive crash...can it be repaired??
yes.
At the Windows XP Recovery Console command prompt (C:WINDOWS>), perform the following steps:
  1. Type the following command:
    cd
    There must be one space between cd and .
  2. Press the <Enter> key to display a C:> prompt.
  3. Type the following command:
    cd system~1_resto~1
    Note the underscore character after the backslash.
10675121.gif NOTE: An Access is denied message may appear. If so, follow the steps below:
    cd windowssystem32config
  2. Press the <Enter> key.
    ren system system.bck
  4. Press the <Enter> key.
  5. Type the following command:
    exit
  6. Press the <Enter> key.
    The system will restart.
  7. Begin again with the first step under Boot the Computer from the Windows XP CD and Start the Recovery Console.
    dir
    Among other information, the dir command will list one or more directories, such as RP1, RP2, and RP3. These directories contain Windows XP Restore Point data.
    Make note of a recently created RP directory, but not one that was created in the past few minutes.
    cd rp<x>
    where <x> equals the restore point data directory number (i.e. RP3).
    cd snapshot
  7. For either error message containing ...CONFIGSOFTWARE:
    1. Type copy _registry_machine_software c:windowssystem32configsoftware.
    For the error message containing ...CONFIGSYSTEM:
    1. Type copy _registry_machine_system c:windowssystem32configsystem.
10675121.gif NOTE: If queried whether to replace the file, press the <Y> key and press the <Enter> key.
    exit
Oct 23, 2009 | Dell Latitude X300 Notebook
I cant get my gateway mt3705 to format,only three options setup available for boot menu,boot seq,setup and psx boot menu..no recovery disc either what do i do?
To delete everything on your hard drive and re-install all factory software: 1 If you can still run Windows: a Click Start, All Programs, Gateway Recovery Center, then click Gateway Recovery Center. The Gateway Recovery Center opens. b Click Recovery, then click Next. Your computer restarts. - OR - 2 If you cannot run Windows: a Turn on or restart your computer. b While the computer is starting up, repeatedly press F8 until the Recovery Options screen opens. If Windows starts to load instead, restart the computer and try again. 3 Press the arrow keys on your keyboard to select Repair Your Computer, then press ENTER. Gateway System Recovery starts, and the System Recovery Options dialog box opens. 4 Select a language and keyboard layout, then click Next. 5 Click the User name box to select a Windows user account, click in the Password box and type the user account’s password (if any), then click Next. The System Recovery Options menu opens. 6 Click Restore Application. The Welcome to Gateway System Recovery window opens. 7 Click Next. 8 To perform a recovery with data backup (recommended), click Recovery with automatic data backup, then click Next. Important Before your hard drive is recovered, your personal files will be automatically backed up to c:\backup. - OR - To perform a full factory recovery without data backup, click Full factory recovery, then click Next. Caution Continuing with the full factory recovery will delete everything on your hard drive. Make sure that you have backed up any important files you want to save. 9 Click Yes, then click Next. The Factory image recovery window opens, which shows you the progress of the system recovery. When recovery is finished, the Recovery is complete window opens. 10 Click Finish, then click Restart. Your computer restarts in its original factory condition. You still need to reinstall any software that was not pre-installed on your computer. If you selected Recovery with automatic data backup in Step 8, you can find your backed up files in c:\backup.
Sep 01, 2009 | Gateway MT3705 Notebook
Problem with pc
Here is the solution right from Microsoft.
SYMPTOMS
When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION
To resolve this issue, use one of the following methods.
Use the Recovery Console Tool
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console.
Determine if the file that is mentioned in the "Symptoms" section of this article is present, and if it is, rename it:
In Recovery Console, change to the c:\Windows folder.
Type cd sytem32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type ren software software.bak (instead of ren system system.bak ), and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
Oct 23, 2007 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
