Question about Toshiba SD-2705 Multi-disc DVD Player
Toshiba SD-2705 Door Will Not Close Nor Will It Play
For some reason the dvd player will not closed properly nor will it play any of my movies. What can I do to fix the problem
SOURCE: Toshiba SD-3980
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
read that
Posted on Mar 23, 2008
SOURCE: won't open...
Hey this is a great site!
I was having a similar problem with my Toshiba SD-K860. Bobbyj, thanks for the link to the SD-4900 service manual, it was extremely helpful even though it was a different model. I could not find an emergency eject pinhole, and leaving the unit unplugged for a while did not help (two suggestions found on other sites), so I simply took the whole thing apart, got the disc out, found the eject slider on the bottom of the tray, massaged the tray open and closed, and put everything back together again. The connections were solid and the belt was in tact so everything seemed to be fine. Once I reassembled and powered it back up it worked again!
I posted a more detailed solution on my problems to solve site, which is similar to this one:
http://problemstosolve.com/solved/toshiba-sd-k850-wont-eject-solved/
Posted on Jun 10, 2008
weaponx69
  • 58 Answers
SOURCE: player will play movies but, skips through music videos
What format are the music videos in?
Posted on Jan 11, 2009
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
  • 4234 Answers
SOURCE: DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Posted on Feb 04, 2009
The open/close door will not open
the problem of this is that the rubber attached to the motor of the mechanism may be slack or cut , replace with the same size and if otherwise replace the whole of the mechanism..
Good luck...
Jun 01, 2010 | Toshiba SD-3950 DVD Player
I can't seem to get the menu button to display any menu. I only use the player for CD/s in a church sound system (connected to a Kenwood Audio Video Reveiver). Also, I can't get the disc player to play...
You will need to the remote to perform these functions. if you have it that's great, if not you willneed to contac Toshiba for a replacement. I ahve a manual for you to print out and keep with the unit. It shows you how to access the menu and to activate random mode..
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/DVD/sd2705.pdf
Sep 16, 2009 | Toshiba SD-2705 Multi-disc DVD Player
Dvd player shuts off during movie
Look at the power supply capacitors to see id any have a bulged top. Those need to be replaced.
Sep 03, 2017 | Toshiba SD-2705 Multi-disc DVD Player
Tray keeps opening and won't play dvd
no your son broke the loadi tray and now it will not aline properlycheaper to buy a new the fix!
Dec 08, 2008 | Toshiba SD-2715 Multi-disc DVD Player
Sound and Video won't play together
Make sure the a/v cables are lined up in the right columns in the back of your tv - ahousehold memebr may have swapped them for some reason or another
Jul 27, 2008 | Toshiba SD-K740 DVD Player
Dvd player not working
If the disc isn't spinning, and you have cleaned the lens (using a proper method) then it is likely that the laser has failed. The disc usually won't spin until the laser has sent/recieved a pulse from the surface of the disc. A new laser is usually about the cost of a new player.
Sep 10, 2007 | Toshiba SD-4900 DVD Player
Can't play dvd-r or dvd+r
try to buy and play original dvd movies. when it play, it is how you burn your dvd, use some software which will automatically create dvd movies so you can play to your DVD player.. If not, try to clean DVD lens using lens cleaner. usually used DVDr will not play to DVD player.. try also to use new blank DVD
Aug 26, 2007 | Toshiba SD-1800 DVD Player
Toshiba SD-2705 Multi-disc DVD Player Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
