Remote will not work when you try to go up or down with channels
  • 2 more comments
  • Nickname9837 Feb 03, 2009
    I have the same problem, but it isn't just the remote, the channel up/down buttons on the TV itself don't work either. The sound on the channel I'm on drops whenever I try to change channels this way.
  • Anonymous Feb 13, 2009
    what the hell i had this tv for about 2 months and still cant fix it!
  • nishant_pyas Mar 11, 2009
    did anyone find a solution to this problem?
  • lisahmarie May 09, 2009
    Mine does the same. Each time I turn on the tv I need to rerun the Auto Search for the channel buttons to work. I should haven't to do that every time I want to watch tv...
Dude its so simple its crazy
GO TO MENU
-TV
-AUTO SEARCH
Not only will it fix the channel button, but it will give you a **** more digital channels
Posted on Mar 29, 2009
My remote won't let me channel down past a certain channel, I can type the numbers in and it will go but if I try to arrow down channels it goes about 5 channels and then starts back over where it started,...
mp_383
What channels are you able to receive? When you press the Select button on DISH remote, which light on the top of the remote lights up? The Sat button should light up when you are in satellite mode. If any other button lights up, press and release the Sat button and then try changing channels. If this doesn't work, we may need to troubleshoot with you. Please call us on 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Mar 08, 2011 | DISH Network 135899 Remote Control
Why does every button work on my universal remote after i program it but the channel up and down
Universal remotes alway have somethings missing functions to comparation to the original remote.Well,ur universal remote don't have channels up and down functions.Try website like Remote.com to buy an original remote.
Oct 21, 2010 | Universal Remote Control Remote Control
Sony trinitron kv32-s15 remote willnot change channels, but, will change on/off and volume.Also, manula channel up/down willnot work
Try to change channels by manually entering the numbers on your remote. If this works then you need to reprogram your channels.
Aug 21, 2010 | Zenith ZN110 Remote Control
Volume and channel up/down keys remote probs
The remote's broken.Find the replacement of the remote with same type, or
if you want to do it yourself, open the remote case, then try cleaning all the rubber pad and the button pad inside the remote using alcohol, this should works.
Mar 07, 2010 | Toshiba CN36V51 TV
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
What is the Remote Control Code for FLX1510
taken from their support f&q section word per word
"try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for Element Electronics in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV’s model number for more information."
Oct 01, 2009 | Element Electronics FLX1510 15.4 in. LCD...
Remote changes channel up but not down
Could be a bad remote controller(well button inside the remote:) ) . Try front function, if works the bad remote control. :)
Apr 14, 2009 | Hitachi 43FDX01B TV
Code for Palsonic 6830TG TV
if the volume down ts working then that means the remote is working if the volume + does not work and the channel + then they need to be cleaned with isopropyl alcohol using a cotton swab, that means you will have to open up the remote control
May 27, 2008 | One For All URC 7740 Remote Control
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Televison & Video Logo
350 people viewed this question
Top Televison & Video Experts
Electro Med Services...
