Question about Toshiba 53H71 53 in. Rear Projection Television
TV vertical field collpses. Toshiba Model CF2668B.
Audio is fine and video just went out. Is there a solution?
I'd like to try to fix it myself. Can someone help?
  • 147 Answers
Very likely it has bad solder connections on the vertical output IC. Or the IC could be bad and needs to be replaced.
Posted on Apr 14, 2009
Trying to connect my inspiron 15 to my toshiba 32af44 and i can't get a picture on my tv. I have bought a pig tail that goes from VGA(the lap top side) to s-video/audio-video cables(tv side) but still...
A simple pigtail won't convert VGA to S-video. The VGA output consists of separate RGB lines and horizontal and vertical synchronization lines.
If you have an adapter that really converts VGA (this output has no audio path) to S-Video and audio lines, then you probably just need to re-select the input through the TV's menu system.
Nov 21, 2010 | Toshiba 32AF44 32" TV
Sega Genesis continually scrolls vertically on Toshiba tv
you need to have a small crappy tv unfortunatly....your 52" wont support it...also you may need to fine tune or find another channel GL
Apr 02, 2010 | Sega Genesis Console
Vertical ghost lines about a 1/2'' apart. Our cable provider changed out the DVR box and rebooted the system and the problem still exist. What is the fix??
The tuner of the TV may be at fault.To bypass/test if the fault is with the TV try hooking up the DVR using audio video cables through video 1 or 2 of TV rather than standard cable through channel 3or(4).
Dec 07, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba CE35f15 TV
This is a vertical circuit problem that is either bad connections on the vertical IC or a defective IC. If you can solder, you can fix this yourself. Look for a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC. There may be defective caps in the circuit as well, but those don't usually cause complete vertical failure. If the picture does not return fully, update this and we'll continue on to the next step.
Dan
Sep 29, 2008 | Toshiba Televison & Video
Fixed green light have audio but no video
it sounds like the tuner went out,you would have to know how to solder and remove the old tuner to be able to do it yourself
Aug 28, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Audio trouble with my tv
use your remote . manually fine tune your tv.
May 05, 2008 | Toshiba 27A33 27" TV
Can't get Video onto Television..Can get Audio.
Thanks for getting back five months later. I ended up buying a new Monster cable that worked just fine for like $40.
Dec 31, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Toshiba TV
If you have audio and no video then something is shutting you High Voltage down. It could be many things. Convergence amps(color problem before shutdown) Vertical problems. Bad caps on 200V line.
Aug 28, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
