Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
One year old 50 inch top half of screen turns to black
When first turned on full screen shows as normal.Within about a minute screen starts to fade to black.If i adjust brightness contrast and color very,very low the picture might last a little longer.It does not fade to black all at once. It will fade with horizontal lines then fade to black. If the power is turned off and you wait about three minutes sometimes the picture may return for an instance.I would like to have a service manual so that i may go over the power supply.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, I am inclined to suspect that the problem is heat related. A couple of ideas you may want to consider/explore:
  • try moving the TV farther away from the wall;
  • temporarily place a ventilator fan blowing air towards the rear of the unit;
  • operate the unit with the rear cover off;
  • check if the fans are turning;
  • electronics wise, would not suggest checking without referencing a service manual. At most that would be practical is to check for the obvious such as blistered/leaky capacitors, burn resistors.
Incidentally, for the service manual, the chassis number would have to be determined. A Philips chassis number would be something like BP2.3U.
Good luck and thank you for using FixYa.
Posted on Feb 03, 2009
  • 744 Answers
Hi.. the problem in ur television is due to the faulty capacitor circuits...Change over of new capacitors will solve ur problem
    Genius:
  • 1,269 Answers
That could be a lamp problem. However, you can start checking the power supply board for any possible faulty component.
Vizio Model# E3D42OVX. Black vertical lines on start up except for top 2"s of screen.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 18, 2017 | Vizio Televison & Video
Bottom half of desktop screen fades to black
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Jul 17, 2012 | Dell Inspiron 530s Desktop Computer
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
I have a Samsung HL-R5087W 50-inch DLP HDTV and half the screen on the right turns black while watching. I have to power the tv down and on again. The full screen returns but turns black within a few...
samdavismd,
It could be either but more than likely from what you describe it is the board which supplies the signal to the light engine. The board in question should have the part number marked on it. See my tip at
http://www.fixya.com/support/r6981868-replace_circuit_board_in_modern_tvs
which will walk you through the process for changing a circuit board.
You can get any parts you need at http://www.encompass.com or http://shopjimmy.com .
Thanks for using FixYa and for the great rating.
hardrocko
Mar 11, 2011 | Televison & Video
I HAVE A LG50PQ30 PLASMA TV,WHICH IS JUST OVER A YEAR OLD AND OUT OF WARRANTY. AFTER THE TV HAS BEEN ON FOR A FEW HOURS THERE IS HORIZONTAL LINES APPEAR ABOUT 6 INCHES FROM THE TOP OF THE SCREEN IT STARTS...
Hello that's a 2010 model set. It sounds like the y sustain board is failing (part # EBR61855101), it usually starts with bad connections on it. A screen shot would be helpful...thanks
Apr 28, 2017 | LG 50PX5D 50 in. Plasma HDTV
Top half of screen malfunctioning - Exactly the same as dclurman
You have a bad upper Y buffer board, not sure what the part# is, but they usually sell for btwn $200-$400
thanks
Eric
Aug 26, 2009 | Pioneer PDP-5060HD 50 in. Plasma...
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
