I need driver for Visioneer Paperport 6100 Scanner
After I reinstalled my windows XP my paperport scanner 6100 made by Visioneer does not work. I need to reinstall driver.
  • opticspro Mar 02, 2009
    i have the same problem. I am not sure even it works for windows 2000. please let me know.
    Problem Solver:
  • 3 Answers
Go on line to the Visioneer web site. You can down load new drivers, manuaals and soft ware...Roy
Posted on Feb 07, 2009
Have an older Visioneer 7100 USB Scanner, Has worked fine for more than 10 years, Now I can't get any scanned objects to appear on my Paperport Desktop. Have no problem using scanner with all other...
Have you upgraded to newer version of windows? Have you tried reinstalling Paperport? (back up max files 1st) I have had a visioneer and still use Paperport 8. Often I have problems with Windows 8 and reinstall paperport now and then.
Mar 07, 2014 | Visioneer Office Equipment & Supplies
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Jul 14, 2011 | Visioneer OneTouch 8900 Flatbed Scanner
Doesnt get connected under windows 7
For the Visioneer OneTouch 5600 Flatbed Scanner in windows 7 go to the visioneer web site at http://support.visioneer.com/products/5600/downloads.asp and download the file 5600.303110.EN.exe. Then right click on the file name and select Trouble shoot compatibility. Do not connect the scanner until told to. Run the program using the recommend settings. That installs the drivers. It does not install the paperport support software but does install the monitor in the task bar. That is enough to use the scanner and save or print the scans.
Sep 08, 2010 | Visioneer OneTouch 5600 Flatbed Scanner
I have replaced my xp computer with one running Vista. Will the Visioneer 6600 scanner work with Vista?
The 48-bit color Visioneer OneTouch 6600 USB scanner delivers outstanding image quality by recognizing over 281 trillion colors at 600x1200 dpi optical resolution. The scanner has three convenient buttons that integrate with the ScanSoft PaperPort Deluxe software to make emailing, copying, and storing images and text effortless. The software bundle also includes ScanSoft TextBridge Pro OCR and MGI PhotoSuite III SE.
The scanner driver is certified by Microsoft for Windows XP, and also is compatible with Windows 98, Windows 2000 and Windows Millennium Edition.
It is not compatible with windows Vista.
Apr 25, 2010 | Office Equipment & Supplies
I have paperport 9.0 and I can't get it to work with Windows 7 which I just installed.
PaperPort 9 is not supported for Win7. You need to upgrade your product or use a Virtual computer running a different OS. PaperPort 10 is being tested with Win7. PaperPort 11.2 and PaperPort 12 are fully supported under Win7. (My household has PaperPort 11. It doesn't work consistently with Win7 and a generic Win7 driver for an older scanner.)
With Win7 Pro or Ultimate, you have the option of downloading and installing the XP mode. (This actually takes two downloads.) Once you are running the virtual XP computer, you can install the PaperPort 9 and the scanner (if you want to capture the files from there). To share images with the real computer, files may need to be stored to external media. Hardware can only be installed to one "computer" and you will be prompted to uninstall the device from the other computer.
I hope this helps.
Feb 19, 2010 | ScanSoft PaperPort Deluxe 9...
Visioneer 8100 and Vista
Help is here,
You have compatibility problems with visioneer and Vista, I helped a few people last week with the same problem.
I recommended them too www.cnet.com for the latest paperport download and got my Fixya button pressed.
Please remember to rate my efforts,
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Jan 19, 2009 | Visioneer OneTouch 8100 Flatbed Scanner
PAPERPORT PICTURE FILE
Open your visioneer software. Scan your image then select the image and display it by clicking the desktop icon at the top tool bar. Then once your image is displayed, go to the pulldown "file" and choose "save-as". Select the format of your choice from the bottom pulldown of the "save-as" window. Of course name you image before saving.
Mar 25, 2008 | Visioneer PaperPort 3100 Flatbed Scanner
143 people viewed this question
jasbo
jasbo
