Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Jenn air range model SCE30600B error code FC blinks with beeping noise. After resetting the temp down to 350 to keep from burning a pizza error code FC started blinking along with continual beeping. I have unplugged stove reset breaker etc. but error code FC reappears.
  • 1 more comment
  • lockwood1980 Feb 22, 2009
    I have the same issue but my oven displays F! . The temperature seems to stay the same. It comes and goes. It started at Thanksgiving and has been intermittent ever since.
  • Anonymous Mar 25, 2009
    I was cooking dinner and after it was done, I turned off my oven and it started to beep and display FC error code. Hit the off button and it stopped for about 30 seconds. I can not get it to stop!!!!!
  • Anonymous Apr 09, 2009
    A month or two ago we noticed a different sound that was almost like a struggling fan inside the oven. It would come and go but otherwise things worked fine. All of a sudden today while cooking we are getting the neverending FC code with the beeping. We can cancel it but it will come back on approx 10 seconds later. I reset the circuit it is connected to and it lets us set the clock. The only buttons that work are the Cook Timer, the Cancel button and the clock settings. Nothing else works. I see several other people have posted recently. It looks like this part has a fairly predicatble life-span.
    Problem Solver:
  • 5 Answers
Replace the entire range: Jennair does not know how to design, make, or program electronics. It makes steel boxes that provide heat but electronics - that's not within their ability. Buy a Kenmore or a GE and your beeping problem will go away.
Posted on Aug 31, 2009
  • 25 Answers
Replace oven sensor.
Posted on Feb 12, 2009
    Problem Solver:
  • 10 Answers
Check your wiring harness, if its OK then replace the power relay board. A faulty board can cause fan issues and pull up the error you are seeing.
Posted on Oct 30, 2009
Jenn air gas electric grill range with convection oven making beeping sound showing -FC- code
FC is a communication error caused by poor connections with the wiring between the logic and relay boards in the unit... Disconnecting and re-connecting the wires and looking for / reflowing the solder joints behind the header connectors will fix your issue
Jul 19, 2016 | Jenn Air Kitchen Ranges
Beeps and flashes FC
The "FC" error code means "Communication error between boards".
Check the "J2" harness, ohm wires end to end.
If the harness is fine then the display board is defective.
Here is the part to order.
Jan 24, 2013 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Error code -fc- beeping will not stop?
From JENN AIR FAULT CODES...
FC - Communication error between boards - Wiring harness or power relay board (PRB)
Hope helps.
Mar 24, 2011 | Jenn-Air Electric Double Oven
It keeps beeping and shows code FC in the window
hi FC is communication error between boards what that means is wiring harness or power relay board(prb)
Oct 15, 2010 | Jenn-Air SVE47100 Slide-In Electric...
I have a Jenn-Air Model SVE47600B/water boiled over
Start by looking at your owners manual which can be downloaded here if you lost yours:
http://www.servicematters.com/maytag_library/docs/16010191.pdf
On page 23 Also called page (1-3) you will see a test procedure, do that first then check the fault code page. Page 26 will detail what the fault codes mean.
F- means there is a fault between the communication boards (replace display board), while FC says the same thing but the result is the different and says replace the PRB. What this tells me is that the problem isnt the board or prb, but that moisture in the area is causing a short, and should be cleaned out with alcohol. If the error code were constant, the board would be bad. In your case, it changes after replug, so I suspect that a thorough clean of the control board area will be all thats needed.
Mar 23, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Beeping noise - letters appear fc
Christina, FC means there is a communication error between your main power board and keyboard. There is a J2 harness that runs between them. You might try to reseat this harness. If that doesn't work the main board will have to be replaced. Catriver..post back.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Since Jenn-Airs codes are F1-F9, the cicuit board may be on the way out since the code resets after you turn it off for a while.
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
2,387 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
