Question about LG LRBN20510WW Bottom Freezer Refrigerator
LG French door express freeze turning on and off
I have a GR-F218NI LG fridge and the express freeze keeps turning on and off randomly it beeps every time it does this, when I lock the water dispenser the problem stops. The cntrol panel does not work at the times when the beeps are occurring IE I cannot lock or unlock or change the Temp until the problem ceases. (temporarily)
SOURCE: Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Posted on Jan 11, 2009
  • 583 Answers
SOURCE: I have an LG french door fridge and its water flow is very slow
it indicates the problem of a leaky water tube or a jammed ice chute,check it. most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs. please do not forget to rate the solution.thanks
Posted on Jun 12, 2009
  • 363 Answers
SOURCE: LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Posted on Jul 30, 2009
  • 166 Answers
SOURCE: LG LRFD25850ST French Door Refrigerator -
Unplug ref for about 5 Min. If does not fix the board in the door may be at fault or the main board.
You may need a service call.
Posted on Jan 20, 2010
  • 161 Answers
SOURCE: LG LRFD25850 French Door Fridge set at 37-40 c
Pull the drawers put and cover the cold air vent (small hole at back wall) with tape ...problem solved!
Posted on Jan 24, 2010
Express freeze
Try and access the coils and see if they are dirty. Cleaning them can sometimes clear up the problem. Dirt works like an insulator and makes the fridge run more than it should so it gets very cold.
Jan 23, 2014 | LG Refrigerators
Maytag french door bottom freezer keeps beeping. It thinks a door is open. Is there anything I can do to stop the beeping?
the door switch might have had liquid poured on it freezing it, or the switch itself is bad, unplug fridge and re plug it in
Oct 31, 2010 | Maytag 25.1 Cu. Ft. Bottom-Mount...
LG LRFD25850 French Door Fridge set at 37-40 c keeps freezing produce at back or in large bottom drawer
Jan 08, 2010 | LG LRFD25850 French Door Refrigerator
LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
Want to dismantle the alarm sound.
I did this before and couldn't remember how. This works on our fridge which has a water dispenser and a bunch of buttons on the left door: Try holding the express freez and lock button for a few seconds. The beeping of the buttons should stop too. I tried countless live chats with the LG people and none of them could help me. I tried a bunch of combinations and found this one to work.
May 01, 2009 | LG LFC25770TT Bottom Freezer French Door...
Hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Nov 18, 2007 | Refrigerators
LG LRBN20510WW Bottom Freezer Refrigerator Logo
545 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
