Question about LG 50PX4DR 50 in. Plasma TV
Grainy picture on LG 50PC5D plasma
What up, man? My 50" plasma has a beautiful picture on digital broadcast, but through HDMI connection to a HD-DVD player the picture is very "grainy" at times. PLEASE HELP
  • LG Master
  • 1,689 Answers
Did you try another HDMI cable?
Did you try another DVD player?
If the above try-outs does not work for you, then the fault is most likely with the HDMI input processor area. For this the set will require service.
Jerry G.
Posted on Feb 10, 2009
Sony KV-32FS13 TV no signal hdmi
Is ur tv a CRT tube type of a analouge tv u are asking?Yes than the tv don't have HDMI inputs hubs for HDMI cables connections.Only some projection tvs,all plasma,LCD and LED tvs have HDMI inputs hubs only and able give ur tv incomming signals HD 1080i for a broadcasting and HD pictures or throught a HD boxes or games devices like Xbox or Playstation 3 devices to get HD output picture for like 1080p.
Jul 12, 2012 | Sony KV-32FS13 TV
What is 1080i and 1080p what cable and HDMI version do I need
So you've got your new Flat Panel Plasma TV and Blu Ray DVD player what cable should you use, am I really 1080p HD Ready ?
So here it is in laymans terms
stands for High-Definition Multimedia Interface. It's a digital interface to get the best, uncompressed digital picture possible.There are currently five versions that are setup as improvement on the last since its introduction in 2003
The first high defintion TV's were classed as HD Ready only the resolutions were set at 1280x720= 921,600 just under a MegaPixel per frame and were called 720p and are capable of viewing only 1080i signals with the correct cable the latest version is called HD Ready 1080p the HDMI standard for this is HDMI 1.3 which means that unless you have a TV that is rated for HDMI 1.3 your 1080p Blu Ray player wont work in full 1080p there will be no picture and the players HDMI output will have to be reduced to 1080i this can be done in the Blu Ray Players settings so you can still watch the video on your older HD Ready television
1080i vs 1080p - Basically both formats have the same number of Pixels 1920 across the top and 1080 across the side this gives a total number of pixels (1920x1080=2,073,600) aka 2 MegaPixels per frame assuming that the aspect ratio is 16:9 this is the same as a basic digital camera or phone jpeg.
You might also see written like this 1080p24 means that it originated from a progressive scanned 24 frames source and has become an established production standard Cimena and for your Blu Ray player will also have this setting if you require it.
When Compared to standard DVD with and aspect ratio of 4:3 which has 720x576=414,720 this is an increase of 500% in the resolution alone over the now humbled DVD Video format with interlaced video
The difference between the two is that one is interlaced (like normal DVD-Video) and the other is progressive OR non-interlaced scan which means that 1080p requires way more transfer speed than that of the 1080i format.
So the main disadvantage of progressive scan is that it requires higher bandwidth than interlaced video that has the same frame size and vertical refresh rate this is why DVD-Videos incorporate the interaced video due to the lack of a digital inteface like HDMI 1.3 rated cable is required to transfer this higher speed of transmission in contrast the 1080i signal requires a much slower speed and HDMI 1.2 rated cable might work.
As far as interconnects go you can still connect your full 1080p Blu Ray Player to your 1080i Plasma TV using the three cable interconnect that comes with the players but for the best possible connection you need to use a HDMI cable with gold plated connecitons. Prices range from £15 right upto £60 and beyond if you go with Monster Cables however the £15 version if it says rated for Blu Ray it will work just fine so save yourself £40.
HD Ready
HDMI 1.0 - combines a digital video signal (standard or HD) with a two-channel audio signal over a single cable used with the HD Ready
HDMI 1.1 - This version adds the ability to transfer not only video and two-channel audio over a single cable, but also added the ability to transfer Dolby Digital, DTS, and DVD-Audio surround signals, as well up to 7.1 channels of PCM audio.
HDMI 1.2 - This version adds the ability to transfer Super Audio CD signals in digital form from a player to a receiver most Home Theatre Systems require at least this type of cable for full capabilty however you can use a v1.3a cable works just as well
HD Ready 1080p
HDMI 1.3 and HDMI 1.3a These versions include improvements in both audio and video capability. With the advent of Blu-ray Disc it adds the ability to transfer the digital bitstreams for the new high resolution audio formats in addition to the standard 24-bit color depth we are used to, HDMI 1.3a has the ability to transfer color depths up to 48-bits, and can accommodate resolutions much higher than the 1080p resolution standard that is in use today on all TVs that are HD Ready 1080p
HDMI 1.4 and HDMI 1.4a HDMI version 1.4 adds practical enhancements for HDMI connectivity. If home theater components, such as HDTVs, Blu-ray Disc players, and Home Theater Receiver, the next step in HDMI of the future is covered by the v1.4a cables wrt to speed.
on Apr 15, 2010 | LG 47 in. Flat-Panel LCD HDTV
Snowy white picture while on cable.
Maybe a tuner problem--considered hooking up whatever you use for signal to the rear av jacks? bypass the problem?
Apr 06, 2012 | LG 50PC5D Television
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
Dec 21, 2011 | Televison & Video
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
I connected my dvd player to my hdtv and its only in black and white. I have adjusted the settings numerous times and it isnt fixed. the cables are all in the right color matching do i fix this?
Ur RCA AV component cable set might bad replace it with another RCA set of cable or tv have HDMI and also DVD player too for HD connection by a HDMI cable through HD hub?Buy and used a HDMI cable connect tv and DVD player to together one HDMI cable for a better functions.
Mar 21, 2011 | Hitachi P50H401 50 in. Plasma HDTV
We have a RCA D52w19 rear projection tv. It appears that the HD feature is not working. My Wii does not recognize it as HD and the picture for Wii, satellite and DVD is noticeably grainy. Is there an easy...
The Wii is not a HD output source. It only displays 480p. If you wish to connect an HD source, you must connect through an HDMI cable or a component Cable. HDMI is better.
Feb 28, 2011 | RCA D52W19 52" Rear Projection Television
I purchased 42" LG Plasma TV and i need to know
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to switch to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate.
Dec 29, 2010 | LG 42LC2D 42 in. LCD HDTV
Watching a football game picture is very unclear
The noise reduction option will cause a blur on fast movement. Also, you probably already know this, but a standard definition broadcast will look very blurry on an HD TV, so make sure the channel you're watching is actually an HD channel.
Oh, wow, I just noticed that this is from October. Oh well, maybe you're still having problems.
Oct 18, 2009 | LG 50PS60 50 in. Plasma HDTV
LG 50PX4DR 50 in. Plasma TV Logo
839 people viewed this question
Computer Repairing
Computer Repairing
