Question about Linksys Wireless-G WRT54G Router
I changed the name of my wireless router and can't connect now
I changed the name of my linksys wireless router and now my laptop or xbox won't connect to it wirelessly. It will connect with an ethernet cable.
Delite your previous saved network and network settings
Posted on Feb 03, 2009
Im trying to get my xbox live nat type to open i have the linksys wrt54gx2 router with srx 200 please help my by giving instructions on fixing this problem.
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Cant connect Xbox 360 to this wireless router
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Linksys WRT160N Wireless Router
I have a Linksys WRT110 and I have two problems. The first is that whenever my roommate connects to the network, he knocks me offline. I don't have a problem connecting to the internet with the desktop, my...
1 If you don't have a switch connected to the router or if your other devices are not on the Wireless allowed list in the router whoever has priority on the connection will knock the others device off that is xbox, laptops etc. Because bandwidth is being decreased and the connection is giving first come first serve priority.
You will need a switch or setup each wireless device in the router .
Instructions:
. power router off
2.connect all three computer you want to connect.
3. start computers one at a time completely
4. check router for status light per computer to see if device is seen by router.
5. open web page to see if each computer is online.
7. do ipconfig / release/renew if not connected
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 07, 2010 | Linksys WRT110 Wireless Router
I've had my linksys wireless G router connected and secured for over a year now. All of a sudden this morning my laptop does not sign in to my network name I can sign in to my router but it doesn't have...
Sometimes it happens that the router might got resetted automatically.
You will need to access the router settings page.
change the wireless settings of the router.
change the network name and the security.
This time create a new network name.
Make sure that your computer will be connected to the router with the cable when you change the wireless settings.
then try to connect to the wireless network.
Click Here for more information about the routers and network
Jul 03, 2010 | Linksys Wireless-G Broadband Router
Microsoft Wireless Network Adapter Xbox 360 can't connect to xbox live and cant obtain IP address
if its having trouble obtaining ip address it sounds liek you need to manually config the connection on the xbox by typing in the name and any wep key and than going into your router and making sure it has multiple ip's available for the xbox for my xbox I had to enter the name of the connection because it was a weak signal despite the proximity I changed it to connect to linksys which was my router name at the time and never had another problem I hope this info helps if nothing I suggested works it may be a problem with your adapter just not having the signal strength if you have had it connected via wire in past and know the router will accept other computers than I would have to say this is your problem
Hope I helped
Please leave feedback
Thanks
Robb
Apr 02, 2010 | Microsoft Wireless Network Adapter Xbox...
Linksys wrt160n router. wireless xbox won't connect
I made it an unsecured connection and everything worked. Not ideal solution, but it worked.
Feb 07, 2010 | Linksys WRT160N Wireless Router
X360 and PC connect - Laptop doesnt!
Looks like you may have WEP security on router and WAP on laptop - or vice versa. Change the laptop to match the router.
Oct 23, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless network disconects when connecting xbox 360
Are you connected to the router wired, or wireless?
Have you set your laptop to a static IP on you network, and your X-box is set to the same?
Jan 29, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect xbox 360 to wireless router
If you use DSL I would also check to make sure you are not being port blocked by your ISP. Some will block you if you exceed bandwidth on a particular port rather than throttling you or shutting you down entirely.
Dec 29, 2008 | Linksys Wireless-G WRT54G Router
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
