Question about HP Compaq nc6000 Notebook
Cant uninstall Belkin Wireless G Plus MIMO Notebook Card
I once did this before under the Start - Run command. Can someone recommend to me how to do this again?
  • JDTec
    JDTec May 11, 2010
    Go to start> control panel > add and remove programs > then when it populates, find the Belkin wireless in the list and click on remove.
  • 520 Answers
I take you have not got the disk..ok you find the program youve downloaded(driver software)
unpack it and double click on the program exe....
if it was a zipped program it will be in c:/unzipped...
start,my computer,c:/(xp)
usually though its a self extracting file and I cant tell you where you have put that...
if youve deleted it youll have to download the file again.
Posted on Feb 10, 2009
Can a belkin network card f5d7050 work with a belkin g plus mimo router
As MIMO is compatible with all wireless g products there shouldn't be any issues at all....
so some questions:
  • do you have other wireless devices working with the router? if so can you duplicate their settings for this n/w card?
  • have you set security on the router?
  • what are you using to connect to the network the windows interface (assuming it's PC not MAC based) or the Belkin one?
i have a linksys g n/w card attached to my MIMO router & it's fine so I'm sure that this is solvable!
Sep 06, 2010 | Belkin F5D9050 Wireless G Plus MIMO USB...
NEED MY ROUTER IP ADRESS CANT LOCATE MANUAL MODEL F5D9230-4
This is from the Belkin Web Site:
Windows 2000, XP, and Vista
1. Click Start, and then select All Programs (XP and Vista) or Programs (2000). 2. Select Accessories, and then Command Prompt (2000, XP, and Vista). 3. At the command prompt, enter: ipconfig 4. The IP address (or IPv4 address is you are using Windows Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx, for example, 192.168.2.2. 5. To close the command prompt, type: exit and press Enter.
Jun 19, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Problems with Belkin Wireless G Plus MIMO Router
- Nope, it is not possible, you may need an Access Point to do it.
Mar 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g+ mimo router can't detect internet
have you tried resetting the network adaptor on the belkin, whictch provider are you using for internet connection?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i get connection using belkin wireless g plus mimo notebook card i have only the card is there still a way i can connect only having the card that goes to my laptop. or do i need a router or can i...
1. If your laptop has a built-in wireless adapter, then you don't need a belkin wireless g plus adapter.
2. You can connect to the Internet using your adapter provided that the location where you at offers wi-fi or wireless connection
3. If you want wireless connectivity at home, then you need to have a wireless router and subscribed for DSL/Cable broadband connections
Nov 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i get an internet connection using belkin wireless g plus mimo notebook card
1) Install the wireless card on your laptop computer (driver)
2) Run wireless utility (windows - Control Panel)
3) Select your wireless network (wireless networks availables) and connect.
If your wireless network have a wep key you need to know that in order to get connected.
To do that you need a wireless router connected to your modem or a wireless modem
Be sure first to have that installed first.
If you have more questions please let me know to help you out better with this issue
Belkin mimo G network card
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 20, 2008 | Belkin Dual-Band Wireless A+G Desktop...
Can not get the wireless g plus mimo notebook card disc to run
Hi again,
Any new development(s) or updates with your concern?
Mar 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
G+ mimo Notebook Card
She probably has both the Mimo Utility and the Windows XP Wireless Configuration Utility running at the same time.. Try disabling the Windows Configuration Utility and see if she can connect now..
Start > Run > Services.msc (OK)
Disable Windows Zero Wireless Configuration
Here is a visual explanation I found:
http://www.ifelix.co.uk/tech/2000.html
Dec 04, 2007 | Belkin High-Speed Mode Wireless G Notebook...
HP Compaq nc6000 Notebook Logo
301 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
