What do you call to an hand-like pointer?
I'am confused...please help me to remember the right term of a mouse pointer in widows XP...It is a hand-like icons...for example...you pointed the my computer,before clicking it...this said pointer will appear first......
........I am hoping for your immediate answer. Thank you !!!!!!!!!!!11
    Sergeant:
  • 219 Answers
Cursor.
Posted on Feb 03, 2009
Laptop pointer erratic
There is a setting in your Control Panel/Mouse, which is a check box to enable it to hide the mouse pointer when not in use. Disable that and see if it helps.
Sep 05, 2014 | Dell Inspiron 1545 Notebook
How do I get rid of AVG search?
Open Chrome.
In the top right hand corner is 3 dots stacked vertically, click on this.
Select Settings, a new tab opens up.
Look for Search and click on Manage search engines ...
Hover the mouse pointer over Google then click on Make Default
Hover mouse pointer over AVG Search and then click on the X to remove it
Click Finished
Click on the X on the Settings tab
Mar 07, 2017 | Microsoft Windows XP Home Edition
I have just connected a quill mouse to my laptop. Right and left clicks work but you can't move the pointer.
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
May 19, 2012 | Computers & Internet
Mouse will not work on touchpad please help
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
also click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark !or question mark ? or a red x right you will have options to update driver software,disable,uninstall,scan for hardware changes and properties
in xp
hope this helps
don
Feb 14, 2011 | Acer Computers & Internet
Logitech mouse stopped working when using my right hand on the mousepad. Will work with my left hand on mousepad or anywhere else. Also will work with right hand if I move the mouse pad to another area. ...
in xp
hope this helps
Jan 17, 2011 | Computers & Internet
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
Mouse pointer drfts to the right side of the screen. I have a touch pad and a mouse button on the keyboard. Even when I connected my usb mouse that pointer drifts as well. I'm not able to control the mouse...
see if your touchpad settings have a setting that controls the sensitivity on the area around the touchpad where you rest your hands on the laptop. I forget what it's called, but most laptops have a setting to control that, so when you rest your hands on the laptop it doesn't affect mouse movement. When you rest your hands, if the sesitivity is too high, the mouse pointer will move when you place your hands to rest on that area.
Jan 10, 2010 | Toshiba Satellite Pro M15-S405 Notebook
I recently had my hard drive reformated and a
You can change the mouse seetngs by going into
Start-> Control Panel-> Mouse
Click on that and you will have a mouse properties dialog box.
In pointer options tab select the pointer speed you desire.
This will help restore the pointer to its normal speed
Jul 12, 2009 | HP Pavilion dv4000 Notebook
Logitech mouse - pointer moves but left clicking doesn't work
Download the latest drivers from this logitech site:
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 14, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Lenovo R52 doesn't remember new mouse pointer speed
Are you trying to configure any external mouse attached or the track ball / touchpad?
Mar 16, 2007 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
