Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Machine turns on, has little suction, then stops working.
While using the corner of a rug got sucked in, machine was turned off.
When using it a few minutes later it just stopped working, The next day it turned on, had very low suction and quit working after a few minutes.
  • judi59art Feb 11, 2009
    Thanks, turns out I changed the pre filter and also found a clog after clearing the clog and filter change, vacuum is as good as new.
    President:
  • 389 Answers
It would be helpful to know what model of vacuum cleaner you're talking about. Basically though, your machine has a blockage somewhere (hence very low suction), and is cutting out after just a few minutes because of overheating.  You need to explore the suction hose (or whatever your machine has), find the blockage and remove it. Blockages almost always happen where the pipe-work takes a sharp bend.  In the worst-case scenario (although in almost all modern machines this is not possible) the blockage may be in the vacuum fan enclosure itself, and then you'll probably need a professional to take care of it.
Posted on Feb 10, 2009
Suction when vacuuming
Some vacuums have a valve or collar near the handle that you can twist to adjust the amount of suction on the vacuum. If you open it a little it will stop sucking up your throw rugs. IF the problem is not enough vacuum then the HEPA filter may be clogged. It's usually a rectangular filter in a plastic frame. That has to be changed occasionally or the suction of the vacuum will continue to drop off.
Apr 04, 2015 | Vacuums
I have a rug doctor blue machine. It will not spray anymore. Great suction. It is connected properly. Any suggestions?
Only two things can be wrong here, either the solution hose is plugged, kinked or undone from it's source, or the pump motor is not working. I'd try the hose first, if you can, take it off at the pump and then turn the machine on. If you get solution pumping out of the unit, then it's not the little pump motor and your problem is in the hose.
Oct 22, 2013 | Rug Doctor Mighty Pro X-3 Ready Pack...
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
While using the power mate rug part I caught a small rug and the vacuum would no longer pick-up .
Check to see if there is a reset button on the head. This protects the machine for times like you described. When something jms up the reset button will turn ofdf th machine. Simply push the reset. Hope this helps, Chris
Feb 07, 2011 | Kenmore Vacuums
Dyson dc14 will not return to fully upright position NEED HELP~!
Try this quick repair and see if this fixes your Dyson: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it. The suction problem is happening because when the machine is put in the upright position it diverts the suction from the floor to the hose automatically, and it's probably stuck in between the lower part and the hose part.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    Apr 21, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
    My shark v1917 jammed on a throw rug, won't start.
    These machines do break VERY easy, however i would wait a couple of hours and try restarting it. If this does not work then i am sorry to say yes it is scrap.
    Apr 15, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
    Little to no suction even with new bag, rug head spits dirt out
    Proably a cloged pipe and suction hose>>> take both ends loose and run a broom stick through it..
    Let me know if this helps and please give a good raiting
    Jan 29, 2009 | Electrolux Guardian Bagged Canister Vacuum
    Hoover Windtunnel carpet level adjustment
    The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
    Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
    Carpet cleaner not doing too well
    there is a dial on the side of the housing move this to tools this diverts the suction from the floor nozzle to the hose,. .
    the brush only rotates slowly.
    If this dose not work check red lint filter, .this is in the back corner of the tank lid ,
    On the turbo brush there is a sliding swicth ,this diverts the suction from the nozzle of the attachment to the attachments brush
    Oct 27, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
    Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
    267 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Roger Potts
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
