Question about Whirlpool GH7145XF Microwave Oven
Light bulb burned out in microwave oven
I have a Whirpool xnr2381753 microwave oven. Installed Nov. 2004. The light bulb has stopped lighting. Presumed to be burned-out. I wasn't having any luck removing this tiny bulb in the top center of the oven. My manuel did not refer to changing the bulb either. So before breaking something, I call their 800 support line. After a few minutes the lady said that replacing the light bulb would require a service tech to change it.
Would you have any alternative recommendations. I would hate to pay $50+ to have a little light bulb replaced.
Thanks,
Jack Ferrell
  • Anonymous May 25, 2009
    I can replace the bulb of a whilpool microwave
  • John A Makela
    John A Makela Oct 24, 2013
    Thanks for the comment. I'll run it without light. Jam
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Posted on Feb 04, 2009
Replace light bulb.
http://www.ehow.com/how_7614605_replace-chef-microwave-light-bulb.html
Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
Mar 07, 2015 | Magic Chef CMV1000B Microwave Oven
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
All the light blew out, the electric still works, but the oven won't heat food
Hi, my living room light has stopped working, When i turned it on one of the little bulbs went pop and light stopped working although all electric and other lights still work. I tried the bulb in a different light and it still works as well?? I also took light off to check for loose wiring etc but all seems to be fine. Can you help? Thanks!
Oct 04, 2009 | Whirlpool Accuwave Microwave Oven
Light under unit stays on
open the oven there are two or three safty switches near door one of the switch is for light if it is short then only light will remain on.by opening door light should come on set the time and hit start light will come again. replace that switch and it will be ok
Aug 07, 2009 | GE Advantium 120 Convection/Microwave Oven
Bulbs burn out quickly and dimmer inoperative
huhnr
the connections at the socket are loose. remove bottom pan and squeeze the electrical connections lightly with a pair of pliers.
doc
Apr 15, 2009 | Whirlpool GH4155XP Microwave Oven
Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
1,415 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
