Question about Vector VEC056 MAXX Power Inverter
My vector power inverter needs to be reset
My vector 2500 watt inverter (veco 56c) has a red fault light on....and no longer provides ac still works...inverter was operating with a discharged battery at the time it quit working....can it be reset? no reset button on the outside of the case....
  • Joel311 Mar 13, 2009
    Same thing with my 3000, there's no reset or GFI. Nothing.
  • Anonymous Mar 29, 2014
    Why does Vecter maxx 1500 watt inverter fault light keep illuminating
Inverters use high power transistors to create an A/C voltage from a D/C input. These transistors are the common point of failure when the units are not cooled properly or used beyond their rated capacity. (Actually, you should always buy an inverter that’s rating for continuous use is well below what your actual need is). What’s most likely happened is that these have shorted out and need to be replaced. Unfortunately, replacement parts alone will likely cost nearly what a new unit costs.
Sorry to be the bearer of bad news; but you basically have a nice paperweight with some pretty lights and fans on it.
Posted on Aug 15, 2009
Circuit diagram
Proprietary info. Good luck on that
Oct 06, 2013 | Vector VEC056D 2500 Watt Power Inverter...
I have a auto pro 800 watt inverter that gives 220volt ac **** wont run my kellerman freezer it runs in the house on ac can you help
If your freezer need more than 800 watts to run then your 800 watt inverter will be overloaded and it will shutdown.
Mar 21, 2012 | Vector 1000w Power Inverter
I have a vector 750 watt inverter (vec1047bd). The charge controller in my photovoltaic system went bad and I had it repaired. When I got the controller back, my inverter did not work. The inverter has a...
If you have a manual for the inverter check and see ifDin there are diagnostic codes with the LEDs.
I looked through this and your description of the problem was not listed in the document, but you may be able to contact the manufacturer and get more information. Basically this is a DC to AC power conversion device, which takes the 12v DC input and converts it to 115V AC
and in does so at a maximum peak power of 750 watts at 115V AC. since your charge controller went bad, it is possible in the process it overloaded this device or the battery system put out too low of a voltage when the charge controller died and low voltage input is not something this unit was able to tolerate. Check your remaining components to be sure they are good, then look at the inverter's board and transformer to see if anything was damaged. I would want to verify the charge controller was good and the batteries in good condition - and perhaps consider replacing this inverter with one more suited to your actual load wattage requirements.
Nov 19, 2017 | Vector VEC1047BD 750 Watt Power Inverter
I bought two veco51d 3000 watt inverters made by vector and conectted with two positive and two negative cables to a good battery 12.6 volts load test at 750 cranking amps and both inverters light up and...
Hello, I hear you. Was the reason to supply 240 volts? When you try the inverters separately, do you get 120Volts output? Let us look at the units working individually first and go from there.
Feb 06, 2011 | Vector 3000 Watt Continuous 6000 Peak Dc...
Bought a new vector maxxsst 1200 watt inverter
Inverter run on batteries sir, and if these batteries are not charged, the run time {the number of hours it will work} reduces.
S0, you will need to connect the inverter to a power source.Theses will allow your batteries to be charged and enable it to run for a long period of time.
Make sure your batteries are still OK.i.e working properly
May 03, 2010 | Vector ® Maxx SST 1200 - watt Power...
Vector 2500 watt inverter red led fault light no output. Model veco56d.
There is a fuse on these things at the back of the case. Could be in a slide out plastic holder, or in a round holder with a knurled screw or bayonet type cap. If this fuse is not blown, then the news is not good.
Mar 21, 2010 | Vector 2000w Power Inverter
I have a vector 3000 watt inveter red fault light is on, wont power a 6.5 amp fuel pump
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
Jan 16, 2010 | Vector Power Inverter - 3000 Watt
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
Burnt out
internal failure possibly on power side, lower than 300A fault current so unit could not trip i/p protection and as fault was post ac section, continued to burn internally.
it just broke
no breakers tripped out so it kept drawing current until the fault burnt away.
maybe this is what happened, need to know a lot more info to change hypothisis
Jun 01, 2009 | Vector VEC056D 2500 Watt Power Inverter...
The fault light stays on my power inverter
Try disconnecting the DC input for 5 min. or so, this will generally reset the unit.
Mar 13, 2009 | Electronics - Others
Vector VEC056 MAXX Power Inverter Logo
1,145 people viewed this question
Top Vector Electronics - Others Experts
Craig Butler
Craig Butler
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
