Question about Ricoh Aficio CL7000 Laser Printer
Dirty copies on Ricoh Aficio CL 7000 copier
I had posted an inquiry earlier. At that point, we had replaced the fusing unit and drum, but were getting dirty copies just like before. Now a new wrinkle has developed. If we set it on color, we do not get the dirty copies. If we set it on rotate/sort (in black and white), we get clean copies as well. Both of these settings slow down the machine, so I suspect that speed has soemthing to do with it. Does anyone have a clue what is going on?
Did you replace the fusing oil as well? toner will not fuse well and deteriorate your new fuser very quickly if you are out of oil
Posted on Feb 18, 2009
How to fix a dirty copies of ricoh aficio mp c305spf
It is the photo drum which is causing this clean it or replace if it does not solve the problem.
Jun 22, 2015 | Ricoh Aficio MP-C305SPF Color Copier :...
Dark back ground on ricoh affico mp3500 replace drum ,Blade pcr. nothing has changed on the copy
Sounds like drum unit not getting charge voltage to it. Check charge roller is in properly point end should face rear of copier and making contact with plate.
Jan 08, 2014 | Ricoh Aficio MP4500, MP3500 Kit
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 back side is dirty?
Problem on charge roller,Upper drum unite,please clean or change it then solve your problem.
With the best luck.
Jan 20, 2010 | Ricoh Aficio 450 Copier
I have replaced the fuser unit and fuser oil, and still getting streaks different places on the paper. Ricoh Aficia CL 7000
One or more of the drum units or the transfer belt cleaning blade is bad. Only way to tell is to remove each drum and check the surface for the toner "streaks". You can also pull out the transfer belt and check the surface for the streaks. It will be one or the other. Now if you streaks are of a particular color then that points more to the drum of that color.
Jan 06, 2010 | Ricoh Aficio CL7000 Laser Printer
Hello sir i have problem in ricoh aficio 1022 image repeat problem. u told me to change hotroller pressure roller baring also i change its same plz tell me where is the problem before fusing copy is ok...
Hi sir; No matter who told you to replace, the hot roller is the most possibility, the next item also last item you need to check is drum unit (drum cleaning blade,[replace it ], image transfer roller [clean up by alcohal] and drum [ depend condition ]).
May 09, 2009 | Ricoh Aficio 1035 Copier
Ricoh CL 7000 down due to an SC-685
Do you have the copier feature option installed?
It is most likely just a loose connection on the interface between the main printer unit and scanner section. Turn off main power (red button), and re-seat the connector.
Please let me know and rate solution :)
Apr 17, 2009 | Ricoh Aficio Colour 3006 Color Copier
AFICIO 551 BLACK AND WHITE
Which feeder? Is it in the document feeder or the paper tray?
Could need a pm to replace the drum, cleaning blade, and possibly developer to get rid of the dirty copy and/or the scanner section should be cleaned as well by cleaning the glass as well as the mirrors underneath the glass.
Dec 10, 2008 | Ricoh Aficio 450 Copier
Ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Nov 05, 2008 | Ricoh Aficio 1035 Copier
Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Apr 24, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh Aficio CL7000 Laser Printer Logo
410 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
