Question about HP LaserJet 1320 Printer
Toner Missing Light Error persists
When I took out the last toner and replaced with a new one, teh toner missing indicator does not go off. I tried a different toner cartridge, I checked paper jams, I powered on/off, I looked at all the pins and clips and nothing seems wrong.
What can be the problem?
  • 1 more comment
  • mmlifshitz Feb 03, 2009
    I tried. It did not help.
  • gw86 Mar 24, 2009
    I have just recently replaced an empty toner in a working hp1320 with a brand new genuine hp 49x toner and the toner light is still flashing orange, I have checked all the paper pathways for jams which there are none of and the contacts on the toner are touching the internal connectors! I have performed all recommended resets from other forums including a cold reset sill with no luck also have tried a number of toners form used to new and genuine and non genuine with no result, cant think of any more ideas, any solutions will be much appreciated
  • Herv? Bizot
    Herv? Bizot Apr 06, 2009
    Some one blocked the cartridge inside the 11320 printer (the axis of the flaf protecting the roll was split).
    After gentle extraction forcing the flap up i removed it and get the blinking "Toner missing " message
    Is there a way to force this diag failure state ( the signal checked through the contacts is likely more than a short )
    May be some may know
    thanks
    RV
  • 31 Answers
Use the eraser end of a pencil and gently clean the contacts in the carriage and then clean the contacts of the ink cartridge.
Posted on Feb 03, 2009
Konica minolta bizhub c250 error C-2AO3
magenta toner cartridge EEPROM access error, cleaned the connection between the toner cartridge and the machine once cleaned if the issue persists remove the toner cartridge and put back in again if again the error persists replace the toner cartridge with a new one and last resort if the issue is still not fixed then replace the mechanical control board.
Oct 04, 2012 | Konica Minolta Minolta Konica Bizhub C250...
Toner sensor error
Hi
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time.
2. Menu window will show OKI USER.
3. Scroll to Engine Dialog Mode is indicated Push Enter button.
4. Diagnostic Mode xx xx xx S Mode is indicated.
5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed.
6. Push Enter button.
7. TONER SENSOR - ENABLE is displayed.
8. Push Enter button.
9. Press (- / +) TONER SENSOR = DISABLE is displayed.
10. Press ON LINE CANCEL buttons at same time.
11. (*) is displayed.
12. Restart the Printer.
Daniel Scott
Jun 22, 2010 | OKI C5150n Led Printer
Power up init fails
When you replaced the photoconductor, did you go through the procedure to reset the photoconductor counter ?
There's no chip on the photoconductor, so you need to reset this manually
Photoconductor Reset Procedures:
Step 1:
Open the front door and hold the
Cancel button until all lights begin to cycle.
Step 2: Close the front door. The warning
clears and the counter resets to zero.
Step 3: Press Continue to resume printing.
Mar 01, 2010 | Lexmark E120n Laser Printer
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
Supply error
This means the toner chip is damaged or missing or can't be read from the printer.
remove the toner cartridge and check if the e-label pin is broken... if so replace it and set the cartridge back
If you have changed the toner recently, or have a third party toner in it. this is the reason ...
You need to replace the toner and if the error is still there then you know it is the reader failing.
thank you
have a nice day
all the best with ur printer
Apr 09, 2009 | HP LaserJet 2605dtn Printer
Blinking error light CH will not let machine turn on
side door of copier is open just close it properly .if error stills just check by pressing start key what is sub code if 00 developer unit is missing if 01toner catridge is missing .just check all connectors of developer unit and toner unit.code will bi removed
Jan 20, 2009 | Sharp AL 1631 Copier
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Kyocera Mita FS-1030D Laser Bottom 2 lights blinking.
I think the two lights flashing together indicates waste toner box missing or full but as this printer doesn't have a waste bottle I assume it means the processing unit (ie the drum bit) needs replacing.
Apr 22, 2008 | Kyocera Mita FS-1030D Laser Printer
HP LaserJet 1320 Printer Logo
388 people viewed this question
Ben Johnson
